2010-07-03, 05:02
Let me start by saying I did some searches before registering/posting and this does not appear to be one of the common mistakes.
Windows 7:
--I'm putting it in ...\Roaming\XBMC\userdata. I'm reasonably sure it's in the right location because other config files there have obviously-modified timestamps, but I've tried it in various other locations anyway.
--it is definitely named .xml and not .xml.txt.
--I haven't done anything else weird like use a rich text editor.
I've tried the following two settings:
<displayremotecodes>true</displayremotecodes>
(Attempting to get the codes to display on screen when setting up a Harmony remote programmed to send XBOX codes. Ended up having to go the MCE Keyboard route for now.)
<timeseekbackward>-7</timeseekbackward>
(Attempting to change from -30 for a shorter skip back.)
I am opening with <advancedsettings> and closing with </advancedsettings> . I am usually copying and pasting from the wiki to avoid typos. I am observing case-sensitivity.
So in other words, my current advancedsettings.xml is as follows:
<advancedsettings>
</advancedsettings>
...and I'm still getting a 30-second backwards seek.
Thoughts? Sorry if I've still managed to overlook something obvious, and thanks.
Windows 7:
<advancedsettings>
</advancedsettings>
