Pages: 1 2 3 4 5 6 7 8 9 10
is tehre still a shoutcast streamer?
i have one and it says it cant connect, so im assuming that shoutcast changed up the method of connection.
is there a working shoutcast as of right now?
happy halloween!
Amet thanks a lot for putting that sound and clear. For me Shoutcast is one of the most important add-ons and I appreciate your effort very much! hvala, best, s
search option is in now, thanks necochino for the idea and the function.
sort by listeners will only work on trunk > r35146, it will not be backported to Dharma branch.
[plugin.audio.shoutcast] -v 1.0.9
- added: search option
- added: sort by listeners, it will only work on trunk > r35146
more changes in search function
[plugin.audio.shoutcast] -v1.1.0
search parameter can be passed from skins or via favourites, thx Necochino
usage: ActivateWindow(10501,"plugin://plugin.audio.shoutcast/?search=<your search query>")
Amet Wrote:more changes in search function
This is great !!! The plugin works like a charm. Love it. Many thanks.
Amet thanks for this implementation. I needed some days to exactly understand your message, but eventually I found nighties that have feature on sorting by listeners installed. Up most useful!
Hvala, sinkalonk.
I'm having a problem installing the v1.1 Shoutcast plug-in. When I try to install it, I get a script error.
When I try to run it under the plugins menu from Music, I get the same error. Any suggestions?
ard9000 Wrote:I'm having a problem installing the v1.1 Shoutcast plug-in. When I try to install it, I get a script error.
Post a debug log please
Amet Wrote:sort by listeners will only work on trunk > r35146, it will not be backported to Dharma branch.
Dear Amet,
I have a question is this sorting by listeners available only in r35146 release? I tried with Dharma RC1 and RC2 and also night build r35571 and this feature is absent.
I'm puzzled abit as you stated that this will be available in trunk > r35146.
best, sinkalonk
sinkalonk Wrote:Dear Amet,
best, sinkalonk
hi,
we look for Dharma, if found we dont sort by listeners, see
here for more.
I cant comment about unofficial nightly builds, not sure how they are built,sorry
Cheers,
Zeljko
I know your last post said you don't comment on nightly builds, but I just compiled SVN35642 and Shoutcast 1.1.0 is now failing. Before I was using an SVN build from the same revision as RC2 (this is the Dharma branch).
Here's the debug output when the script runs.
18:45:09 T:2820651888 M:1289994240 DEBUG: xbp_dlopen loading python lib /usr/local/lib/xbmc/system/python/python24.zip/pyexpat.so. flags: 2
18:45:09 T:2820651888 M:1290375168 DEBUG: Loading: /home/dan/.xbmc/temp/pyexpat.so
18:45:09 T:2820651888 M:1290375168 DEBUG: RegisterExtensionLib, adding pyexpat.so (0xad3a0d90)
18:45:09 T:2820651888 M:1290375168 DEBUG: xbp_dlsym - load symbol initpyexpat
18:45:09 T:2820651888 M:1290375168 INFO: -->Python script returned the following error<--
18:45:09 T:2820651888 M:1290375168 ERROR: Error Type: xml.parsers.expat.ExpatError
18:45:09 T:2820651888 M:1290375168 ERROR: Error Contents: no element found: line 1, column 0
18:45:09 T:2820651888 M:1289994240 ERROR: Traceback (most recent call last):
File "/home/dan/.xbmc/addons/plugin.audio.shoutcast/default.py", line 172, in ?
INDEX()
File "/home/dan/.xbmc/addons/plugin.audio.shoutcast/default.py", line 44, in INDEX
for stat in minidom.parseString(link).firstChild.getElementsByTagName('genre'):
File "../Python/Lib/xml/dom/minidom.py", line 1925, in parseString
File "../Python/Lib/xml/dom/expatbuilder.py", line 940, in parseString
File "../Python/Lib/xml/dom/expatbuilder.py", line 223, in parseString
ExpatError: no element found: line 1, column 0
18:45:09 T:2820651888 M:1289994240 INFO: -->End of Python script error report<--
18:45:09 T:3055572864 M:1289994240 DEBUG: ------ Window Init (DialogKaiToast.xml) ------
18:45:09 T:3055572864 M:1289994240 DEBUG: Alloc resources: 0.03ms (0.02 ms skin load)
18:45:09 T:2820651888 M:1289994240 INFO: Python script stopped
18:45:09 T:2820651888 M:1289994240 DEBUG: Thread 2820651888 terminating
18:45:09 T:2857241456 M:1289994240 DEBUG: WaitOnScriptResult - plugin exited prematurely - terminating
18:45:09 T:3055572864 M:1289994240 ERROR: GetDirectory - Error getting plugin://plugin.audio.shoutcast/?initial=list
18:45:09 T:3055572864 M:1289994240 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.audio.shoutcast/?initial=list) failed
18:45:09 T:3055572864 M:1289994240 DEBUG: CGUIMediaWindow::GetDirectory (plugin://plugin.audio.shoutcast/)
18:45:09 T:3055572864 M:1289994240 DEBUG: ParentPath = [addons://sources/audio/]
18:45:09 T:3055572864 M:1289994240 DEBUG: Loading fileitems [plugin://plugin.audio.shoutcast/]
We use this plugin a lot, and I figured it might be useful for you to know there's an issue before Dharma releases another build.
