Turn the volume up in xbmc.
Do you have boost level on output selected?
R_N_B Wrote:Do you have boost level on output selected?
can't seem to find any boost level thingy..
so what is the fix for this, i too have this problem. the volume is nearly half that of MPC
cinemmatic Wrote:can't seem to find any boost level thingy..
Go to system - audio output - third option down. Just click to enable. Does make a difference.
BTW I use the latest nightlies, I simply install over the last version. They can be found here.
LINK
I don't see this option. Am I supposed to have it in version 9.11 ?
