2010-07-05, 21:25
I'm sure I screwed something up because I don't really understand Linux or the procedure for upgrading Live. I was running Karmic SVN 28256 and I'm trying upgrade to latest SVN Lucid. I went into my sources.list and changed every instance of 'karmic' to 'lucid'. I then ran the following:
After that I rebooted and was greeted with a tiny OpenGL error message. I then closed XBMC and ran:
It returns saying that the latest Nvidia graphics driver is already installed (256.35).
Isn't that a really old version? How do I get this fixed and get my XBMC back up and running?
EDIT: It turns out that 256.35 is a current dirver. So why do I get the OpenGL error?
sudo add-apt-repository ppa:team-xbmc-svn/ppa
sudo add-apt-repository ppa:nvidia-vdpau/ppa
sudo apt-get remove xbmc*
sudo apt-get update
sudo apt-get upgrade
sudo apt-get install xbmc xbmc-live
sudo nvidia-installer --update
