Installed xbmc live 9.11 to usb stick
I have mounted 2 ntfs hdd (eg. sda1=movie1 & sdb1=movie2)
and I can see both hdd´s content....
updated to latest svn r31657 & latest nvidia driver 256.35
everything vent fine. But now when I look a my 2 hdd, they show the same
content (eg. sda1=movie1 & sdb1=movie1) ??
Reverting to 9.11 and all is good, again showing both hdd´s content.
Does somebody have a clue what I did wrong, because this cant be a bug, right?
jubaz Wrote:Hi,
I seem to remember there was a change not so long ago in that XBMC now mounts hdds by UUID instead of device name. Seems like a long shot, but maybe your disks have the same UUID?
ls /dev/disk/by-uuid/ -l
UUID - Universally Unique Identifier
root@XBMCLive:~# ls /dev/disk/by-uuid/ -l
total 0
lrwxrwxrwx 1 root root 10 2010-07-09 11:10 14F6188DB6E84C49 -> ../../sdb1
lrwxrwxrwx 1 root root 10 2010-07-09 11:10 6178C1DB15235EC8 -> ../../sda1
lrwxrwxrwx 1 root root 10 2010-07-09 11:10 74955ce7-ef02-4e29-8e08-e254d0258521 -> ../../sdc5
lrwxrwxrwx 1 root root 10 2010-07-09 11:10 c82cbdfa-b5d2-4d2c-a928-5816d31854aa -> ../../sdc1
each hardware piece is unique, no need to change.
So thats not the problem.... Thanks though..
Tried to check my disks with df:
and you can see that both sda1/sdb1 looks the same, but they are not..... hmm
root@XBMCLive:~# df
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/sdc1 1826268 1272460 461036 74% /
udev 1548204 292 1547912 1% /dev
none 1548204 0 1548204 0% /dev/shm
none 1548204 284 1547920 1% /var/run
none 1548204 0 1548204 0% /var/lock
none 1548204 0 1548204 0% /lib/init/rw
/dev/sda1 976760000 951607508 25152492 98% /media
/dev/sdb1 976760000 951607508 25152492 98% /media
root@XBMCLive:~#
If you copied your df output right, they both got mounted on the same directory, that's why you're seeing only one content. I don't know what live uses to manage mountpoints, but that's likely the culprit.
I've seen a few of these posts lately. Try editing your fstab and manually setting your mount points for sda1 and sdb1, then reboot.
cowfodder Wrote:I've seen a few of these posts lately. Try editing your fstab and manually setting your mount points for sda1 and sdb1, then reboot.
I am a total linux noob here...
would you mind to make an example of how to do that.
I looked at my fstab, and I have no clue....
fstab:
proc /proc proc defaults 0 0
# / was on /dev/sdc1 during installation
UUID=c82cbdfa-b5d2-4d2c-a928-5816d31854aa / ext4 errors=remount-ro 0 1
# swap was on /dev/sdc5 during installation
UUID=74955ce7-ef02-4e29-8e08-e254d0258521 none swap sw 0 0
/dev/scd0 /media/cdrom0 udf,iso9660 user,noauto,exec,utf8 0 0
/dev/fd0 /media/floppy0 auto rw,user,noauto,exec,utf8 0 0
Don't look like your drives are listed, you would have to add them.
https://help.ubuntu.com/community/Fstab
Something like this.
UUID=14F6188DB6E84C49 /media/movie1 ntfs defalt 0 0
You also need to create the directory /media/movie1
Sorry for the late followup, was on weekend.
success though.. Thanks for you help everyone.
I put together what I did, in case someone else is looking for the same.
Shows your UUID of your devices
like example:
Then:
# sudo mkdir /media/disk1
# sudo mkdir /media/disk2
# sudo nano -b /etc/fstab
Insert below in /etc/fstab:
UUID=14F6188DB6E84C49 /media/disk1 ntfs defalt 0 0
UUID=6178C1DB15235EC8 /media/disk2 ntfs defalt 0 0
save with ctrl X, press Y, Press ENTER
# sudo reboot
