2010-07-09, 04:30
first HI im new to the forums and to XBMC. I love the overall look and feel of XBMC but i am having a problem with audio.
I am using windows 7 on a PC that has 7.1 audio trough analog and also has TOSLINK output.
I have a 5.1 audio receiver with both options to use toslink or multichannel inputs.
i will explain a littlebit of how I had my setup before XBMC because i think it will help you help me because i dont know much about codecs,formats ect...
So I playd all my movies on a samsung bluray player that would wirelessly connect to my main computer wich had all my media stored in it. I have movies that will play with DTS and some other dont. but for the movies that do not play in DTS, instead of using the TOSLINK I would use the analog multichannel input and the sound was 5.1 surround beutifull. the only setting I changed was my receiver from TOSLINK to multichannel.
Now I have XBMC and I am trying to do the same but it is not working. again the movies that do play in DTS sound perfect but the otherones i am having problem. first when in analog multichannel the center speaker sound was coming from the left surround speaker so I had to switch the connections behind the PC so that the center speaker will play the correct sound. the problem with this is that now in windows sound configuration it is messed up. now the center will play the left surround and the right surround will play the subwoofer. and to be honest I would not mind how windows sounds aslong as XBMC will play my movies with perfect sound. but its not. Even when the sound is now showing from the correct speaker the surround sound is not working correctly I have to increase the volume on the receiver almost to MAX and the subwoofer is not doing much, i am missing sounds.
is there a solution. I know my explanation might be a mess so ask me if you have question and i will reply
