Full Version: Export of TV Series library putting season tbn's in wrong place?
HI,
I have the following directory structure:
TV_Series/24/Season 1/episodes...
TV_Series/24/Season 2/episodes...
TV_Series/24/Season 3/episodes...
etc...
When I export library, the .tbns for each of the seasons (season01.tbn, seaso02.tbn, etc), all get placed in the TV_Series directory... I would expect them to go in the TV_Series/24 directory (they are specific to that show).
Bug?
I can recall it's already fixed. What revision of XBMC you're running?
XBMC.exe indicates File Version 9.11.0.0
Is this what you are looking for?
(Windows x86 version)
No. The Revision is part of the system information window. It's also printed at the top of the xbmc.log.
XBMC 9.11 R26017 (Compiled : Dec 23 2009)
You might want to update to a recent nightly build if you're not scared of some lighter bugs Wink Otherwise you'll have to wait for the new version that will hopefully arrive soon.
Thanks. I'll wait Smile
