Full Version: Git in Linux
I've just set up my revo and want to update my Night skin using Git.
I've used XBMCFreaks latest iso and installed to the Revo HDD.
I've run these commands using putty:
sudo apt-get install git-core
cd ~/.xbmc/addons
git clone git://github.com/bartowski/skin.night.git
and I get back:
-bash: git: command not found
Can someone explain what is wrong please.
bobo1on1 Wrote:sudo apt-get install git-core
and....? That really wasn't worth your time replying as it means nothing to me or anyone else looking for an answer.
Is that what is wrong? Why? How? What is correct?
Oh, I didn't read the first line.
Check if /usr/bin/git exists and that /usr/bin is in the PATH environment variable.
make sure you run
sudo apt-get update
before
cheers
harryzimm Wrote:make sure you run
sudo apt-get update
That did the trick.
Linux = strange.
