2010-07-10, 03:54
Starting XBMC, Platform: Windows build 7600. Built on Dec 23 2009 (SVN:26017, compiler 1500)
Folder called "z:\Sopranos", set to TV content, default scraper thetvdb.com
Files inside folder called Sopranos s4d1.iso, Sopranos s4d2.iso, etc. Note - these are rips of the entire discs - not the individual episodes.
Can't get artwork to show up, either at folder level or at disc level. Tried "selected folder contains a single TV show" on and off - neither helps.
Part of logfile:
21:38:41 T:7428 M:995725312 DEBUG: No NFO file found. Using title search for 'Z:\Sopranos\'
21:38:41 T:7428 M:995725312 DEBUG: CIMDB::InternalFindMovie: Searching for 'sopranos' using TheTVDB.com scraper (file: 'tvdb.xml', content: 'tvshows', language: 'multi', date: '2009-07-28', framework: '1.1')
21:38:41 T:7428 M:995663872 DEBUG: FileCurl::Open(07A4D530) http://www.thetvdb.com/api/GetSeries.php...anguage=en
21:38:44 T:7428 M:995667968 DEBUG: FileCurl::Close(07A4D530) http://www.thetvdb.com/api/GetSeries.php...anguage=en
21:38:44 T:7428 M:995663872 DEBUG: scraper: GetSearchResults returned <?xml version="1.0" encoding="utf-8" standalone="yes"?><results><entity><title>The Sopranos</title><language>en</language><url cache="75299.xml">http://www.thetvdb.com/api/1D62F2F90030C444/series/75299/all/en.zip</url><id>75299</id></entity></results>
Further entries show things being downloaded ("adding new items to tvshows:z:\sopranos", banners, actors, thumbnails).
Not sure what I'm doing wrong - appreciate any advice. Thanks in advance.
Part of logfile:
