2010-07-10, 23:59
2010-07-11, 11:02
hey check out "tv renamer" instead it has many more features and i could never get natburs to work properly. it also has easy command line arguments
2010-07-11, 20:01
I did check out TVrename, and I can't make heads or tails out of the Reg Ex, code that needs to be entered for some offbeat names. With TVrenamer, I can add an offbeat title directly to the program and it will remember the naming convention from then on. I find that much better and easier than TVrename.
Thanks anyway,
Mark
Thanks anyway,
Mark
2010-07-13, 15:35
Might I recommend theRenamer, this is the application I use, it allows you to use it in command line. I hope this helps!
Reg
Reg
2010-07-13, 18:59
Hi Reginald,
I have tried TheRenamer as well. The thing that I didn't like about it was sometimes when I would come back to my PC, I would have a message on my screen from google saying that I have "exceeded my alotted number of searches" and was prohibited from doing any more searches for a while. I didn't know what to do to stop the excessive searches, so I stopped using it. I will probably go back to it though and try to configure the naming a little better.
Thanks,
Mark
Thanks,
Mark
2010-07-13, 22:57
I'm confused to what you mean you've used to many Google Searches? I wasn't aware it searched Google.
I've been using it for about a year or so and I've wrote some batch scripts that copy files into a folder at a certain time and it renames all of my shows and movies and of course it moves them to where I tell them.
Later I have another script that launches Media Info Plus via command line that grabs all my episode images.
2010-07-14, 00:03
I didn't realize it either until I started getting the google messages and then I read this on the TheRenamer page
When you drag shows to theRenamer, it first checks your database for the ShowName/IDcode.
IF the show is not listed in your database, it will try to google for it.
Once a successful file is renamed, theRenamer automatically adds the ShowName/IDcode to your database.
There is NO NEED to add the ShowName/IDcode for every show.
theRenamer does a great job in finding your show automatically, even with spelling errors in your file's ShowName.
I guess it was my fault I got all the google messages, but it also says that shows don't have to be entered into the database.
Mark
Mark
2010-07-14, 13:52
I guess I have been lucky as I haven't had it give me any errors yet, but I tend to put names manually into the list if I think it will have problems.
Reg
Reg
2011-01-14, 02:54
I tried having it add automatically, but it wasn't working for me.
So, I cranked up a couple episodes of Doughton's Abbey and waded through plugging them manually.
Now - no more google checks, and only at the cost of a couple of hours of my time. (I have a LOT of TV shows).
