Full Version: Movies Sorting
I have a problem when sorting movies, they keep getting sorted from Z-A. Previously they were always sorted the other way around. Even when sorting by year or rating etc. its always Z-A. After restarting xbmc a few days ago the sorting order changed Huh
Selecting ascending or descending doesn't change a thing
Deleted guisettings but still same problem
Removed source and re added them and still no change
I've updated to SVN 31689 but still same problem as older builds
actors, directors, studios, music etc. are sorted the right way but cant get movies to sort like that.
How can i change this??
How do you select ascending/ descending?
some skins have the option to choose if ascending or descending when sorting and used to work before, now whatever I choose its always from Z-A
where, how?
Are you pressing the arrows next to sorting?
yes the arrows or options next to sorting
I got it now, had to change to ascending in reFocus skin, the same option in the other skins wasn't working, now it's good for all skins.
