2014-07-24, 16:45
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157
2014-07-24, 20:56
Hi Giftie,
I seem to be having problems executing the database update, prior to executing I had artists from A-Z and now after updating the artist lists ends with just A-B and very little in the B section. My XBMC library is the same, infact I just added more which is why I#m executing CDartmanager.
Sorry, can't give you my logfile. xbmclog says it has been censored and won't upload it. Pastebin says entry is too large.
I have the file saved if there is another way to get it to you?
Perhaps it is connected to what Kode has asked as I did notice a constant repeat of 'ALBUM NOT MATCHED ON FANART.TV' in the logfile?
2014-07-25, 00:16
finally got it working! But some in my collection doest have artwork/fanart esp if the album is Various Artist collection.
Can one do it manually put a fanart with those artist have none? i tried putting one fanart as a test but when i played the song it doest show up.
2014-07-25, 08:49
@iceman600, yes you should be able to do it manually, for artists, create fanart / folder / logo / banner etc in the artist folder for albums put folder / cdart in the actually album folder. You might have to update / re-scan your library for XBMC to find the relevant images.
2014-07-25, 18:11
having a bug when try to start the plugin
I already reinstall the plugin, delete C:\Users\Nat\AppData\Roaming\XBMC\userdata\addon_data\script.cdartmanager\
but still have this issue
18:05:33 T:10772 NOTICE: [cdART Manager] - Looking for settings.xml
18:05:33 T:10772 NOTICE: [cdART Manager] - Addon Work Folder: C:\Users\Nat\AppData\Roaming\XBMC\userdata\addon_data\script.cdartmanager\
18:05:33 T:10772 NOTICE: [cdART Manager] - Addon Database: C:\Users\Nat\AppData\Roaming\XBMC\userdata\addon_data\script.cdartmanager\l_cdart.db
18:05:33 T:10772 NOTICE: [cdART Manager] - Addon settings: C:\Users\Nat\AppData\Roaming\XBMC\userdata\addon_data\script.cdartmanager\settings.xml
18:05:33 T:10772 NOTICE: [cdART Manager] - Addon Work Folder Found, Checking For Database
18:05:33 T:10772 NOTICE: [cdART Manager] - Addon Db not found, Must Be First Run
18:05:33 T:10772 ERROR: EXCEPTION: XML File for Window is missing
18:05:33 T:10772 NOTICE: [cdART Manager] - Error in script occured
18:05:33 T:10772 ERROR: Traceback (most recent call last):
18:05:33 T:10772 ERROR: File "C:\Users\Nat\AppData\Roaming\XBMC\addons\script.cdartmanager\default.py", line 535, in <module>
18:05:33 T:10772 ERROR: ui = gui.GUI( "script-cdartmanager.xml" , __addon__.getAddonInfo('path'), "Default")
18:05:33 T:10772 ERROR: RuntimeError: XML File for Window is missing
2014-07-25, 23:42
(2014-07-25, 08:49)Mike_Doc Wrote: [ -> ]@iceman600, yes you should be able to do it manually, for artists, create fanart / folder / logo / banner etc in the artist folder for albums put folder / cdart in the actually album folder. You might have to update / re-scan your library for XBMC to find the relevant images.
I did put a fanart.jpeg on the artist folder it still not showing up. I did refreshed my xbmc library and also did refeeshed the database in cdart manager (which takes too long. Just like the first time i did the database) and still the fanart didnt show up.
2014-08-01, 13:05
Hi Giftie,
here is a debug log from latest stalling issue when program is 'checking fanart.tv for new artwork'
http://xbmclogs.com/show.php?id=258215
hope you can help as this and the artists issue are the problems I'm having at the moment.
Mike.
Mike.
2014-08-09, 08:24
Do i have to update the database library every time I add a music or an album? Is there a quicker way not to scan all the library again? Im asking because i have a huge music library and every time i add a song or an album the update database is taking forever just to add the previous album or song i add.
2014-08-10, 21:02
(2014-08-09, 08:24)iceman600 Wrote: [ -> ]Do i have to update the database library every time I add a music or an album? Is there a quicker way not to scan all the library again? Im asking because i have a huge music library and every time i add a song or an album the update database is taking forever just to add the previous album or song i add.I use The Scheduler addon to update the cdART database at night when I'm not using the htpc.
2014-08-19, 04:57
(2014-08-10, 21:02)bryanbrazil Wrote: [ -> ](2014-08-09, 08:24)iceman600 Wrote: [ -> ]Do i have to update the database library every time I add a music or an album? Is there a quicker way not to scan all the library again? Im asking because i have a huge music library and every time i add a song or an album the update database is taking forever just to add the previous album or song i add.I use The Scheduler addon to update the cdART database at night when I'm not using the htpc.
I wish there was a run in the background option so i can still use my htpc while the database is updating
2014-08-24, 22:57
When i try to run cdART nothing happens other than the error below.
Full lLOG file here
Full lLOG file here
13:40:57 T:3880 DEBUG: [cdART Manager] - sys.argv[0]: script.cdartmanager
13:40:57 T:3880 NOTICE: [cdART Manager] - Addon Work Folder: C:\Users\Admin\AppData\Roaming\XBMC\userdata\addon_data\script.cdartmanager\
13:40:57 T:3880 NOTICE: [cdART Manager] - Addon Database: C:\Users\Admin\AppData\Roaming\XBMC\userdata\addon_data\script.cdartmanager\l_cdart.db
13:40:57 T:3880 NOTICE: [cdART Manager] - Addon settings: C:\Users\Admin\AppData\Roaming\XBMC\userdata\addon_data\script.cdartmanager\settings.xml
13:40:57 T:3880 NOTICE: [cdART Manager] - Addon Work Folder Found, Checking For Database
13:40:57 T:3880 NOTICE: [cdART Manager] - Addon Db Found, Checking Database Version
13:40:57 T:3880 NOTICE: [cdART Manager] - Looking for database version: 3.0.3
13:40:57 T:3880 NOTICE: [cdART Manager] - Database matched
13:40:57 T:3880 ERROR: EXCEPTION: XML File for Window is missing
13:40:57 T:3880 NOTICE: [cdART Manager] - Error in script occured
13:40:57 T:3880 ERROR: Traceback (most recent call last):
13:40:57 T:3880 ERROR: File "C:\Users\Admin\AppData\Roaming\XBMC\addons\script.cdartmanager\default.py", line 535, in <module>
13:40:57 T:3880 ERROR: ui = gui.GUI( "script-cdartmanager.xml" , __addon__.getAddonInfo('path'), "Default")
13:40:57 T:3880 ERROR: RuntimeError: XML File for Window is missing
13:40:57 T:2580 DEBUG: ------ Window Deinit () ------
13:40:57 T:2580 DEBUG: ------ Window Deinit (DialogAlbumInfo.xml) ------
13:40:57 T:2580 DEBUG: CApplication::ExecuteXBMCAction : Translating clearProperty(ArtistSlideshow.ExternalCall)
13:40:57 T:2580 DEBUG: CApplication::ExecuteXBMCAction : To clearProperty(ArtistSlideshow.ExternalCall)
13:40:57 T:2580 DEBUG: ------ Window Init () ------
13:40:57 T:3880 INFO: Scriptresult: Success
13:40:57 T:3880 INFO: Python script stopped
13:40:57 T:3880 DEBUG: Thread XBPyThread 3880 terminating
13:40:57 T:2580 DEBUG: waiting for python thread 26 (C:\Users\Admin\AppData\Roaming\XBMC\addons\script.cdartmanager\default.py) to stop
13:40:57 T:2580 DEBUG: python thread 26 (C:\Users\Admin\AppData\Roaming\XBMC\addons\script.cdartmanager\default.py) destructed
2014-08-29, 18:38
(2014-08-24, 22:57)CaptainKen Wrote: [ -> ]When i try to run cdART nothing happens other than the error below.
Full lLOG file here
Code:13:40:57 T:3880 DEBUG: [cdART Manager] - sys.argv[0]: script.cdartmanager
Bump.
2014-09-05, 21:15
I get the following error after the initial album scan:
21:02:47 T:4736352256 DEBUG: [cdART Manager] - Path does not exist: 'sftp://user:passwd@ip:22/media/Music/Yellow Submarine'
21:02:47 T:4736352256 DEBUG: Previous line repeats 14 times.
21:02:47 T:4736352256 DEBUG: [cdART Manager] - XBMC Music Library does not exist, aborting database creation
21:02:47 T:4736352256 DEBUG: [cdART Manager] - Retrieving Local Album Artists from Database
21:02:47 T:4736352256 ERROR: Traceback (most recent call last):
21:02:47 T:4736352256 ERROR: File "/Users/user/Library/Application Support/XBMC/addons/script.cdartmanager/resources/lib/database.py", line 619, in get_local_artists_db
21:02:47 T:4736352256 ERROR: c.execute(query)
21:02:47 T:4736352256 ERROR: OperationalError: no such table: lalist
21:02:47 T:4736352256 NOTICE: [cdART Manager] - Checking for artist match with fanart.tv - First Check
21:02:47 T:4736352256 DEBUG: DialogProgress::StartModal called (already running)!
21:02:47 T:4736352256 DEBUG: ------ Window Init (DialogProgress.xml) ------
21:02:47 T:4736352256 DEBUG: [cdART Manager] - Storing Album Artists List
21:02:47 T:4736352256 DEBUG: [cdART Manager] - Storing lalist
21:02:47 T:4736352256 DEBUG: [cdART Manager] - Finished Storing lalist
21:02:47 T:4736352256 DEBUG: [cdART Manager] - Counting Local Artists, Albums and cdARTs
21:02:47 T:4736352256 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <class 'sqlite3.OperationalError'>
Error Contents: no such table: counts
File "/Users/user/Library/Application Support/XBMC/addons/script.cdartmanager/resources/lib/gui.py", line 71, in onInit
self.setup_all()
File "/Users/user/Library/Application Support/XBMC/addons/script.cdartmanager/resources/lib/gui.py", line 1048, in setup_all
first_check( all_artists, local_artists )
File "/Users/user/Library/Application Support/XBMC/addons/script.cdartmanager/resources/lib/fanarttv_scraper.py", line 356, in first_check
store_fanarttv_datecode( present_datecode )
File "/Users/user/Library/Application Support/XBMC/addons/script.cdartmanager/resources/lib/database.py", line 430, in store_fanarttv_datecode
local_artist_count, album_count, artist_count, cdart_existing = new_local_count()
File "/Users/user/Library/Application Support/XBMC/addons/script.cdartmanager/resources/lib/database.py", line 718, in new_local_count
c.execute(query)
OperationalError: no such table: counts
2014-09-11, 08:32
(2014-08-19, 04:57)iceman600 Wrote: [ -> ](2014-08-10, 21:02)bryanbrazil Wrote: [ -> ](2014-08-09, 08:24)iceman600 Wrote: [ -> ]Do i have to update the database library every time I add a music or an album? Is there a quicker way not to scan all the library again? Im asking because i have a huge music library and every time i add a song or an album the update database is taking forever just to add the previous album or song i add.I use The Scheduler addon to update the cdART database at night when I'm not using the htpc.
That's a good question, cuz I'm running cdArt for the first time and it's going on 14 hours building a database. It's just halfway lol! If you guessed correctly, yes I have 4000+ albums! So, when I add anything and want to update my collection, I have to wait about a day before it's finished? I just wanted to test this add-on out and I've been waiting for myself to use this haha! I think background updating would be great.
Edit: I saw there is an option to run database update in background. Doh!
2014-10-02, 16:00
Is there an option to have the CDart stored and read from a central network location? I have several XBMC devices and (as I understand it) each holds local CDart info. Would be great if this could be run on my media server and the other devices reference it. Is that possible?
