Full Version: [RELEASE] cdART Manager Script
(2015-05-17, 07:19)ThaDraGun Wrote: [ -> ]Not sure how to get this working.
Looking at the screenshots on page one I notice that mine does not show any info at the bottom (Local artists, local discs, locak cdarts) are all blank. ..No numbers. So I'm assuming that means it thinks I have no music, or doesnt see it. My music is added to Kodi, it shows up just fine in library mode.
I tried choosing advanced - modify addon database - refresh addon database
It does look like its doing something. It takes a long time to go through it all. Then I see no change.
I tried selecting other options and it does nothing.
Album cdarts - select artist
- automatic download
etc etc
Nothing happens.
I tried uninstalling, then installing this version: https://github.com/stefansielaff/script....tree/Helix
and no difference. However, after I reinstalled the settings were still in the addon so Im not sure if it completely uninstalled.
on kodi 14.2
Try exiting Kodi, and go into the addon settings folder for cdART Manager, delete the Database file and any backups that have been created, then restart Kodi, and start the cdART Manager addon again. When the plugin starts, it will see there is no existing DB and attempt to recreate it from scratch. If you have Library Updates on startup enabled, you will need to wait until the update completes before starting cdART Manager, as it cannot access the library DB at the same time as an update is being processed (locked DB). Be aware that sometimes, a second scan via cdART Manager *may* be required if you see that very few/none of your artists have been successfully recognized (green) by cdART Manager. I have witnessed this myself, but am not a coder so don't know why it happens. This may also be a symptom of DB locking, but cannot be sure as I don't routinely wipe my cdART Manager DB unless I have cause to do so.
Hope this helps.
EDIT: Stef.an's version is the only version that will work with Kodi 14 upwards, so this is the version you should be running. You can rename the extracted folder to just "script.cdartmanager" and place it in your addons folder, but be sure to remove the existing folder first to avoid conflicts with the older version. Addon settings are stored in the "addon_settings" folder which is completely separate to the "addons" folder, hence settings will be retained even if an addon is uninstalled and later re-installed. To wipe the settings for any addon, either use a "reset to defaults" option if existing in that particular addon, or browse to your userdata/portable_data -> addon_data folder and remove the folder corresponding to the addon whose settings you wish to remove/reset.
Need your help :
I have a lot of artists that have many issues of wallpaper like , NSYNC because the software recognize them as *N Sync (but i cant name the folder with * in it Smile ) or Justin Timberlake (dont see fanart at all), Robbie Williams and more , even that i see the logo i dont see any of the fanart or extrafanart, sometimes like Britney Spears i see the fanart but its not changing for the extrafanart .
Anyone knows what is the issue ? or have a fix for me Huh
Is this plugin still supported? Will it sometime work with Isengard?
works here with 15 beta2 fine. (openelec)
The only issue I have is when Music is playing, and I open The Addon, I dont get the Progress PopUp, the Addon works but I cant see how long it would take, If is stop the Music, the Progress PopUp appears.
"supported" is a matter of opinion - if you talk about compatibility updates: Yes, I'm still here and I still use the plugin, so I'll update it and publish the changes if needed Smile
The Helix branch of my fork still works for me on Isengard beta 2.
guandms, this sounds like a skin or settings issue to me, I think your skin doesn't even look for the fanart, search for a fanart path setting somewhere in your skin's music library view
meowmoo, interesting! I'll check the popup when the final Isengard is released, sometimes such issues resolve themselves Wink
Currently I'm a little busy jumping out of planes to get my skydiving license this summer but ... given that I survive haha ... I'm considering a cleanup and re-release this fall if anyone is interested, brave enough and willing to help me test it.
im willing to help you test no issues , the problem was on my PC , in OpenELEC it was working great (really strange same settings)
But no issues for testing ...
(2015-06-24, 17:03)stef.an Wrote: [ -> ]Currently I'm a little busy jumping out of planes to get my skydiving license this summer but ... given that I survive haha ... I'm considering a cleanup and re-release this fall if anyone is interested, brave enough and willing to help me test it.
Well good Luck with Skydiving !!
I'll be willing to beta test "The Living Daylights"out of new CE ... ( Pun intended.. )
eagerly awaiting !TongueCool
I am having problems with freezing when the manager starts. I have tried many of the remedies in the thread, with no luck.
Here is my debug log.
http://xbmclogs.com/pryrihkaz
Any help would be appreciated, thank you.
Mhhh, I can't see any attempt to start the script in this log, am I wrong?
(2015-06-29, 17:51)stef.an Wrote: [ -> ]Mhhh, I can't see any attempt to start the script in this log, am I wrong?
Yah, I am having to close Kodi before creating the debug file.
Here is the log...
09:58:10 T:4308  NOTICE: [cdART Manager] - ############################################################
09:58:10 T:4308  NOTICE: [cdART Manager] - #    cdART Manager                                         #
09:58:10 T:4308  NOTICE: [cdART Manager] - #        default.py module                                 #
09:58:10 T:4308  NOTICE: [cdART Manager] - #    script.cdartmanager                                   #
09:58:10 T:4308  NOTICE: [cdART Manager] - #    Giftie                                                #
09:58:10 T:4308  NOTICE: [cdART Manager] - #    4.0.5                                                 #
09:58:10 T:4308  NOTICE: [cdART Manager] - #    Ppic, Reaven, Imaginos, redje, Jair,                  #
09:58:10 T:4308  NOTICE: [cdART Manager] - #    Chaos_666, Magnatism, Kode, Martijn                   #
09:58:10 T:4308  NOTICE: [cdART Manager] - #    Thanks for the help guys...                           #
09:58:10 T:4308  NOTICE: [cdART Manager] - #    Frodo                                                 #
09:58:10 T:4308  NOTICE: [cdART Manager] - Looking for settings.xml
09:58:10 T:4308   DEBUG: [cdART Manager] - Settings
09:58:10 T:4308   DEBUG: [cdART Manager] -           backup_during_update: true
09:58:10 T:4308   DEBUG: [cdART Manager] -                    backup_path:
09:58:10 T:4308   DEBUG: [cdART Manager] -            change_period_atend: true
09:58:10 T:4308   DEBUG: [cdART Manager] -                     check_mbid: false
09:58:10 T:4308   DEBUG: [cdART Manager] -             enable_all_artists: false
09:58:10 T:4308   DEBUG: [cdART Manager] -            enable_fanart_limit: false
09:58:10 T:4308   DEBUG: [cdART Manager] -                 enable_hdlogos: true
09:58:10 T:4308   DEBUG: [cdART Manager] -                 enable_missing: true
09:58:10 T:4308   DEBUG: [cdART Manager] -         enable_replace_illegal: false
09:58:10 T:4308   DEBUG: [cdART Manager] -                   enablecustom: false
09:58:10 T:4308   DEBUG: [cdART Manager] -                   enableresize: false
09:58:10 T:4308   DEBUG: [cdART Manager] -                   fanart_limit: 10
09:58:10 T:4308   DEBUG: [cdART Manager] -                         folder: 0
09:58:10 T:5752   DEBUG: ------ Window Deinit (Pointer.xml) ------
09:58:10 T:4308   DEBUG: [cdART Manager] -             illegal_characters: :*<>/\|?"
09:58:10 T:5752   DEBUG: ------ Window Deinit () ------
09:58:10 T:4308   DEBUG: [cdART Manager] -                          local: 32082
09:58:10 T:5752   DEBUG: ------ Window Init () ------
09:58:10 T:5752   DEBUG: ------ Window Init (Pointer.xml) ------
09:58:10 T:4308   DEBUG: [cdART Manager] -                     localcdart: 32083
09:58:10 T:4308   DEBUG: [cdART Manager] -                       mb_delay: 9
09:58:10 T:4308   DEBUG: [cdART Manager] -              mbid_match_number: 10
09:58:10 T:4308   DEBUG: [cdART Manager] -                   missing_path:
09:58:10 T:4308   DEBUG: [cdART Manager] -                     music_path: C:\Users\Joetta\Desktop\Music\
09:58:10 T:4308   DEBUG: [cdART Manager] -             musicbrainz_server: http://musicbrainz.org
09:58:10 T:4308   DEBUG: [cdART Manager] -           notify_in_background: false
09:58:10 T:4308   DEBUG: [cdART Manager] -                     recognized: 32078
09:58:10 T:4308   DEBUG: [cdART Manager] -                         remote: 32080
09:58:10 T:4308   DEBUG: [cdART Manager] -                    remotelocal: 32080
09:58:10 T:4308   DEBUG: [cdART Manager] -              replace_character: _
09:58:10 T:4308   DEBUG: [cdART Manager] -               resizeondownload: false
09:58:10 T:4308   DEBUG: [cdART Manager] -                      unmatched: 32084
09:58:10 T:4308   DEBUG: [cdART Manager] -                   unrecognized: 32083
09:58:10 T:4308   DEBUG: [cdART Manager] -             update_musicbrainz: true
09:58:10 T:4308   DEBUG: [cdART Manager] -                use_musicbrainz: true
09:58:10 T:4308   DEBUG: [cdART Manager] - sys.argv[0]:
09:58:10 T:4308  NOTICE: [cdART Manager] - Addon Work Folder: C:\Users\Joetta\AppData\Roaming\Kodi\userdata\addon_data\script.cdartmanager\
09:58:10 T:4308  NOTICE: [cdART Manager] - Addon Database: C:\Users\Joetta\AppData\Roaming\Kodi\userdata\addon_data\script.cdartmanager\l_cdart.db
09:58:10 T:4308  NOTICE: [cdART Manager] - Addon settings: C:\Users\Joetta\AppData\Roaming\Kodi\userdata\addon_data\script.cdartmanager\settings.xml
09:58:10 T:4308  NOTICE: [cdART Manager] - Addon Work Folder Found, Checking For Database
09:58:10 T:4308  NOTICE: [cdART Manager] - Addon Db Found, Checking Database Version
09:58:10 T:4308  NOTICE: [cdART Manager] - Looking for database version: 3.0.3
09:58:10 T:4308   ERROR: Traceback (most recent call last):
09:58:10 T:4308   ERROR:   File "C:\Users\Joetta\AppData\Roaming\Kodi\addons\script.cdartmanager\default.py", line 482, in <module>
09:58:10 T:4308   ERROR:     c.execute(query)
09:58:10 T:4308   ERROR: OperationalError: no such table: counts
09:58:10 T:4308  NOTICE: [cdART Manager] - # Error: OperationalError
09:58:10 T:4308  NOTICE: [cdART Manager] - Trying To Delete Database
09:58:10 T:4308   ERROR: XFILE::CFile::Delete - Error deleting file C:\Users\Joetta\AppData\Roaming\Kodi\userdata\addon_data\script.cdartmanager\l_cdart.db
09:58:12 T:5752   DEBUG: ------ Window Init (C:\Users\Joetta\AppData\Roaming\Kodi\addons\script.cdartmanager\resources\skins\Default\720p\script-cdartmanager.xml) ------
09:58:12 T:5752    INFO: Loading skin file: C:\Users\Joetta\AppData\Roaming\Kodi\addons\script.cdartmanager\resources\skins\Default\720p\script-cdartmanager.xml, load type: LOAD_ON_GUI_INIT
09:58:12 T:5752   DEBUG: POParser: loaded 191 strings from file C:\Users\Joetta\AppData\Roaming\Kodi\addons\script.cdartmanager\resources\language\English\strings.po
09:58:12 T:5752   DEBUG: Previous line repeats 139 times.
09:58:12 T:5752   DEBUG: CGUIMediaWindow::GetDirectory ()
09:58:12 T:5752   DEBUG:   ParentPath = []
09:58:12 T:4308  NOTICE: [cdART Manager] - # Setting up Script
09:58:12 T:4308  NOTICE: [cdART Manager] - Addon Db found - Loading Counts
09:58:12 T:4308   DEBUG: [cdART Manager] - Counting Local Artists, Albums and cdARTs
09:58:12 T:4308   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                            Error Type: <class 'sqlite3.OperationalError'>
                                            Error Contents: no such table: counts
                                              File "C:\Users\Joetta\AppData\Roaming\Kodi\addons\script.cdartmanager\resources\lib\gui.py", line 71, in onInit
                                                self.setup_all()
                                              File "C:\Users\Joetta\AppData\Roaming\Kodi\addons\script.cdartmanager\resources\lib\gui.py", line 1037, in setup_all
                                                all_artist_count, local_album_count, local_artist_count, local_cdart_count = new_local_count()
                                              File "C:\Users\Joetta\AppData\Roaming\Kodi\addons\script.cdartmanager\resources\lib\database.py", line 718, in new_local_count
                                                c.execute(query)
09:58:15 T:5752    INFO: XCURL::DllLibCurlGlobal::CheckIdle - Closing session to http://feeds.xbmc.org (easy=0B54E268, multi=005985A8)
09:58:17 T:5752   DEBUG: CApplication::ProcessMouse: trying mouse action rightclick
09:58:17 T:4308  NOTICE: [cdART Manager] - Closing
09:58:17 T:4308  NOTICE: [cdART Manager] - Saving missing.txt file
09:58:17 T:4308   DEBUG: [cdART Manager] - Retrieving Local Albums Database
09:58:17 T:4308   DEBUG: DialogProgress::StartModal called
09:58:17 T:4308   DEBUG: ------ Window Init (DialogProgress.xml) ------
09:58:17 T:4308    INFO: Loading skin file: DialogProgress.xml, load type: KEEP_IN_MEMORY
09:58:17 T:4308   ERROR: Traceback (most recent call last):
09:58:17 T:4308   ERROR:   File "C:\Users\Joetta\AppData\Roaming\Kodi\addons\script.cdartmanager\resources\lib\database.py", line 570, in get_local_albums_db
09:58:17 T:4308   ERROR:     c.execute(query)
09:58:17 T:4308   ERROR: OperationalError: no such table: alblist
09:58:17 T:5752   DEBUG: ------ Window Deinit (DialogProgress.xml) ------
09:58:17 T:4308   DEBUG: [cdART Manager] - Finished Retrieving Local Albums from Database
09:58:17 T:4308   DEBUG: [cdART Manager] - Retrieving All Local Artists from Database
09:58:17 T:4308   ERROR:   File "C:\Users\Joetta\AppData\Roaming\Kodi\addons\script.cdartmanager\resources\lib\database.py", line 619, in get_local_artists_db
09:58:17 T:4308   ERROR: OperationalError: no such table: local_artists
09:58:17 T:4308   DEBUG: [cdART Manager] - Retrieving Local Album Artists from Database
09:58:17 T:4308  NOTICE: [cdART Manager] - Path for missing.txt file not provided
09:58:17 T:5752   DEBUG: ------ Window Deinit (C:\Users\Joetta\AppData\Roaming\Kodi\addons\script.cdartmanager\resources\skins\Default\720p\script-cdartmanager.xml) ------
09:58:17 T:4308    INFO: CPythonInvoker(7, C:\Users\Joetta\AppData\Roaming\Kodi\addons\script.cdartmanager\default.py): script successfully run
09:58:17 T:4308    INFO: Python script stopped
09:58:17 T:4308   DEBUG: Thread LanguageInvoker 4308 terminating
09:58:18 T:5752   DEBUG: CApplication::ProcessMouse: trying mouse action rightclick
09:58:18 T:5752   DEBUG: CGUIWindowManager::PreviousWindow: Deactivate
09:58:19 T:5752   DEBUG: ------ Window Deinit (MyPrograms.xml) ------
09:58:19 T:5752   DEBUG: CGUIWindowManager::PreviousWindow: Activate new
09:58:19 T:5752   DEBUG: ------ Window Init (Home.xml) ------
09:58:19 T:2460   DEBUG: XFILE::CPluginDirectory::StartScript - calling plugin Library Data Provider('plugin://service.library.data.provider/','3','?type=playliststats&id=ActivateWindow(Programs,Addons,return)')
09:58:19 T:2916  NOTICE: Thread LanguageInvoker start, auto delete: false
09:58:19 T:2916    INFO: initializing python engine.
09:58:19 T:2916   DEBUG: CPythonInvoker(8, C:\Users\Joetta\AppData\Roaming\Kodi\addons\service.library.data.provider\default.py): start processing
09:58:19 T:2460   DEBUG: XFILE::CPluginDirectory::WaitOnScriptResult - waiting on the Library Data Provider (id=8) plugin...
09:58:19 T:1216  NOTICE: Thread LanguageInvoker start, auto delete: false
09:58:19 T:1216    INFO: initializing python engine.
09:58:19 T:1216   DEBUG: CPythonInvoker(9, C:\Users\Joetta\AppData\Roaming\Kodi\addons\script.skinshortcuts\default.py): start processing
09:58:19 T:1216  NOTICE: -->Python Interpreter Initialized<--
09:58:19 T:1216   DEBUG: CPythonInvoker(9, C:\Users\Joetta\AppData\Roaming\Kodi\addons\script.skinshortcuts\default.py): the source file to load is "C:\Users\Joetta\AppData\Roaming\Kodi\addons\script.skinshortcuts\default.py"
09:58:19 T:1216   DEBUG: CPythonInvoker(9, C:\Users\Joetta\AppData\Roaming\Kodi\addons\script.skinshortcuts\default.py): setting the Python path to C:\Users\Joetta\AppData\Roaming\Kodi\addons\script.skinshortcuts;C:\Users\Joetta\AppData\Roaming\Kodi\addons\script.module.simplejson\lib;C:\Users\Joetta\AppData\Roaming\Kodi\addons\script.module.unidecode\lib;C:\Program Files (x86)\Kodi\system\python\DLLs;C:\Program Files (x86)\Kodi\system\python\Lib;C:\Program Files (x86)\Kodi\python27.zip;C:\Program Files (x86)\Kodi\system\python\lib\plat-win;C:\Program Files (x86)\Kodi\system\python\lib\lib-tk;C:\Program Files (x86)\Kodi;C:\Program Files (x86)\Kodi\system\python;C:\Program Files (x86)\Kodi\system\python\lib\site-packages
09:58:19 T:1216   DEBUG: CPythonInvoker(9, C:\Users\Joetta\AppData\Roaming\Kodi\addons\script.skinshortcuts\default.py): entering source directory C:\Users\Joetta\AppData\Roaming\Kodi\addons\script.skinshortcuts
09:58:19 T:2916  NOTICE: -->Python Interpreter Initialized<--
09:58:19 T:2916   DEBUG: CPythonInvoker(8, C:\Users\Joetta\AppData\Roaming\Kodi\addons\service.library.data.provider\default.py): the source file to load is "C:\Users\Joetta\AppData\Roaming\Kodi\addons\service.library.data.provider\default.py"
09:58:19 T:2916   DEBUG: CPythonInvoker(8, C:\Users\Joetta\AppData\Roaming\Kodi\addons\service.library.data.provider\default.py): setting the Python path to C:\Users\Joetta\AppData\Roaming\Kodi\addons\service.library.data.provider;C:\Users\Joetta\AppData\Roaming\Kodi\addons\script.module.simplejson\lib;C:\Program Files (x86)\Kodi\system\python\DLLs;C:\Program Files (x86)\Kodi\system\python\Lib;C:\Program Files (x86)\Kodi\python27.zip;C:\Program Files (x86)\Kodi\system\python\lib\plat-win;C:\Program Files (x86)\Kodi\system\python\lib\lib-tk;C:\Program Files (x86)\Kodi;C:\Program Files (x86)\Kodi\system\python;C:\Program Files (x86)\Kodi\system\python\lib\site-packages
09:58:19 T:2916   DEBUG: CPythonInvoker(8, C:\Users\Joetta\AppData\Roaming\Kodi\addons\service.library.data.provider\default.py): entering source directory C:\Users\Joetta\AppData\Roaming\Kodi\addons\service.library.data.provider
09:58:19 T:2916   DEBUG: CPythonInvoker(8, C:\Users\Joetta\AppData\Roaming\Kodi\addons\service.library.data.provider\default.py): instantiating addon using automatically obtained id of "service.library.data.provider" dependent on version 2.1.0 of the xbmc.python api
09:58:19 T:1216   DEBUG: CPythonInvoker(9, C:\Users\Joetta\AppData\Roaming\Kodi\addons\script.skinshortcuts\default.py): instantiating addon using automatically obtained id of "script.skinshortcuts" dependent on version 2.14.0 of the xbmc.python api
09:58:19 T:5752   DEBUG: Keyboard: scancode: 0x2b, sym: 0x005c, unicode: 0x005c, modifier: 0x0
09:58:19 T:5752   DEBUG: CApplication::OnKey: backslash (0xf05c) pressed, action is ToggleFullScreen
09:58:19 T:5752   DEBUG: CWinSystemWin32::SetFullScreen (windowed) on screen 0 with size 720x480, refresh 0.000000
09:58:19 T:5752   DEBUG: CWinSystemWin32::ResizeInternal - resizing due to size change (0,0,1366,768 fullscreen)->(315,114,1051,632)
09:58:19 T:5752   DEBUG: CWinEventsWin32::WndProc: window move event
09:58:19 T:5752   DEBUG: CWinEventsWin32::WndProc: window resize event
09:58:19 T:5752   DEBUG: CRenderManager::UpdateDisplayLatency - Latency set to 0 msec
09:58:20 T:2916   DEBUG: Library Data Provider: script version 0.0.9 started
09:58:20 T:2460   DEBUG: XFILE::CPluginDirectory::WaitOnScriptResult- plugin returned successfully
09:58:20 T:2916   DEBUG: Library Data Provider: script version 0.0.9 stopped
09:58:20 T:2916    INFO: CPythonInvoker(8, C:\Users\Joetta\AppData\Roaming\Kodi\addons\service.library.data.provider\default.py): script successfully run
09:58:20 T:2916    INFO: Python script stopped
09:58:20 T:2916   DEBUG: Thread LanguageInvoker 2916 terminating
09:58:20 T:1216    INFO: CPythonInvoker(9, C:\Users\Joetta\AppData\Roaming\Kodi\addons\script.skinshortcuts\default.py): script successfully run
09:58:20 T:1216    INFO: Python script stopped
09:58:20 T:1216   DEBUG: Thread LanguageInvoker 1216 terminating
09:58:23 T:5752   DEBUG: CWinEventsWin32::WndProcWindow is active
09:58:26 T:5752   DEBUG: ------ Window Deinit (Pointer.xml) ------
09:58:43 T:5752   DEBUG: SECTION:UnloadDelayed(DLL: special://xbmcbin/system/ImageLib.dll)
09:58:49 T:5500   DEBUG: Thread JobWorker 5500 terminating (autodelete)
09:58:50 T:2460   DEBUG: Thread JobWorker 2460 terminating (autodelete)
09:58:52 T:6540   DEBUG: CAESinkDirectSound::Deinitialize: Cleaning up
09:58:53 T:5752   DEBUG: CJoystick::Initialize : No Joystick found
09:58:53 T:5752   DEBUG: CWinEventsWin32::WndProcWindow is active
09:59:33 T:5752   DEBUG: Previous line repeats 1 times.
09:59:33 T:5752   DEBUG: CJoystick::Initialize : No Joystick found
09:59:33 T:5752   DEBUG: CWinEventsWin32::WndProcWindow is active
09:59:33 T:5752   DEBUG: ------ Window Init (Pointer.xml) ------
09:59:35 T:5752   DEBUG: CApplication::ProcessMouse: trying mouse action leftclick
09:59:35 T:5752   DEBUG: Keyboard: scancode: 0x2b, sym: 0x005c, unicode: 0x005c, modifier: 0x0
09:59:35 T:5752   DEBUG: CApplication::OnKey: backslash (0xf05c) pressed, action is ToggleFullScreen
09:59:35 T:5752   DEBUG: CWinSystemWin32::SetFullScreen (windowed fullscreen) on screen 0 with size 1366x768, refresh 59.940056
09:59:35 T:5752   DEBUG: CWinSystemWin32::ResizeInternal - resizing due to size change (315,114,1051,632)->(0,0,1366,768 fullscreen)
09:59:35 T:5752   DEBUG: CWinEventsWin32::WndProc: window move event
09:59:35 T:5752   DEBUG: CWinEventsWin32::WndProc: window resize event
09:59:35 T:5752   DEBUG: CRenderManager::UpdateDisplayLatency - Latency set to 0 msec
09:59:37 T:5752   DEBUG: CApplication::ProcessMouse: trying mouse action wheelup
09:59:37 T:5752   DEBUG: CApplication::ProcessMouse: trying mouse action wheeldown
09:59:38 T:5752   DEBUG: Previous line repeats 1 times.
09:59:38 T:5752   DEBUG: CApplication::ProcessMouse: trying mouse action wheelup
09:59:38 T:5752   DEBUG: CApplication::ProcessMouse: trying mouse action leftclick
09:59:38 T:5752   DEBUG: Activating window ID: 10001
09:59:39 T:5752   DEBUG: ------ Window Deinit (Home.xml) ------
09:59:39 T:5752   DEBUG: ------ Window Init (MyPrograms.xml) ------
09:59:39 T:5752   DEBUG: CGUIMediaWindow::GetDirectory (addons://sources/executable/)
09:59:39 T:5752   DEBUG:   ParentPath = [addons://sources/executable/]
09:59:39 T:4300  NOTICE: Thread BackgroundLoader start, auto delete: false
09:59:39 T:4300   DEBUG: Thread BackgroundLoader 4300 terminating
09:59:39 T:6428  NOTICE: Thread JobWorker start, auto delete: true
09:59:40 T:5752   DEBUG: CApplication::ProcessMouse: trying mouse action leftclick
09:59:40 T:3300  NOTICE: Thread LanguageInvoker start, auto delete: false
09:59:40 T:3300    INFO: initializing python engine.
09:59:40 T:3300   DEBUG: CPythonInvoker(10, C:\Users\Joetta\AppData\Roaming\Kodi\addons\script.cdartmanager\default.py): start processing
09:59:40 T:3300  NOTICE: -->Python Interpreter Initialized<--
09:59:40 T:3300   DEBUG: CPythonInvoker(10, C:\Users\Joetta\AppData\Roaming\Kodi\addons\script.cdartmanager\default.py): the source file to load is "C:\Users\Joetta\AppData\Roaming\Kodi\addons\script.cdartmanager\default.py"
09:59:40 T:3300   DEBUG: CPythonInvoker(10, C:\Users\Joetta\AppData\Roaming\Kodi\addons\script.cdartmanager\default.py): setting the Python path to C:\Users\Joetta\AppData\Roaming\Kodi\addons\script.cdartmanager;C:\Program Files (x86)\Kodi\addons\script.module.pil\lib;C:\Users\Joetta\AppData\Roaming\Kodi\addons\script.module.simplejson\lib;C:\Program Files (x86)\Kodi\system\python\DLLs;C:\Program Files (x86)\Kodi\system\python\Lib;C:\Program Files (x86)\Kodi\python27.zip;C:\Program Files (x86)\Kodi\system\python\lib\plat-win;C:\Program Files (x86)\Kodi\system\python\lib\lib-tk;C:\Program Files (x86)\Kodi;C:\Program Files (x86)\Kodi\system\python;C:\Program Files (x86)\Kodi\system\python\lib\site-packages
09:59:40 T:3300   DEBUG: CPythonInvoker(10, C:\Users\Joetta\AppData\Roaming\Kodi\addons\script.cdartmanager\default.py): entering source directory C:\Users\Joetta\AppData\Roaming\Kodi\addons\script.cdartmanager
09:59:40 T:3300   DEBUG: CPythonInvoker(10, C:\Users\Joetta\AppData\Roaming\Kodi\addons\script.cdartmanager\default.py): instantiating addon using automatically obtained id of "script.cdartmanager" dependent on version 2.1.0 of the xbmc.python api
09:59:40 T:3300   DEBUG: POParser: loaded 191 strings from file C:\Users\Joetta\AppData\Roaming\Kodi\addons\script.cdartmanager\resources\language\English\strings.po
09:59:40 T:3300  NOTICE: [cdART Manager] - ############################################################
09:59:40 T:3300  NOTICE: [cdART Manager] - #    cdART Manager                                         #
09:59:40 T:3300  NOTICE: [cdART Manager] - #        default.py module                                 #
09:59:40 T:3300  NOTICE: [cdART Manager] - #    script.cdartmanager                                   #
09:59:40 T:3300  NOTICE: [cdART Manager] - #    Giftie                                                #
09:59:40 T:3300  NOTICE: [cdART Manager] - #    4.0.5                                                 #
09:59:40 T:5752   DEBUG: ------ Window Deinit () ------
09:59:40 T:3300  NOTICE: [cdART Manager] - #    Ppic, Reaven, Imaginos, redje, Jair,                  #
09:59:40 T:3300  NOTICE: [cdART Manager] - #    Chaos_666, Magnatism, Kode, Martijn                   #
09:59:40 T:5752   DEBUG: ------ Window Deinit (Pointer.xml) ------
09:59:40 T:3300  NOTICE: [cdART Manager] - #    Thanks for the help guys...                           #
09:59:40 T:5752   DEBUG: ------ Window Init () ------
09:59:40 T:3300  NOTICE: [cdART Manager] - #    Frodo                                                 #
09:59:40 T:5752   DEBUG: ------ Window Init (Pointer.xml) ------
09:59:40 T:3300  NOTICE: [cdART Manager] - Looking for settings.xml
09:59:40 T:3300   DEBUG: [cdART Manager] - Settings
09:59:40 T:3300   DEBUG: [cdART Manager] -           backup_during_update: true
09:59:40 T:3300   DEBUG: [cdART Manager] -                    backup_path:
09:59:40 T:3300   DEBUG: [cdART Manager] -            change_period_atend: true
09:59:40 T:3300   DEBUG: [cdART Manager] -                     check_mbid: false
09:59:40 T:3300   DEBUG: [cdART Manager] -             enable_all_artists: false
09:59:40 T:3300   DEBUG: [cdART Manager] -            enable_fanart_limit: false
09:59:40 T:3300   DEBUG: [cdART Manager] -                 enable_hdlogos: true
09:59:40 T:3300   DEBUG: [cdART Manager] -                 enable_missing: true
09:59:40 T:3300   DEBUG: [cdART Manager] -         enable_replace_illegal: false
09:59:40 T:3300   DEBUG: [cdART Manager] -                   enablecustom: false
09:59:40 T:3300   DEBUG: [cdART Manager] -                   enableresize: false
09:59:40 T:3300   DEBUG: [cdART Manager] -                   fanart_limit: 10
09:59:40 T:3300   DEBUG: [cdART Manager] -                         folder: 0
09:59:40 T:3300   DEBUG: [cdART Manager] -             illegal_characters: :*<>/\|?"
09:59:40 T:3300   DEBUG: [cdART Manager] -                          local: 32082
09:59:40 T:3300   DEBUG: [cdART Manager] -                     localcdart: 32083
09:59:40 T:3300   DEBUG: [cdART Manager] -                       mb_delay: 9
09:59:40 T:3300   DEBUG: [cdART Manager] -              mbid_match_number: 10
09:59:40 T:3300   DEBUG: [cdART Manager] -                   missing_path:
09:59:40 T:3300   DEBUG: [cdART Manager] -                     music_path: C:\Users\Joetta\Desktop\Music\
09:59:40 T:3300   DEBUG: [cdART Manager] -             musicbrainz_server: http://musicbrainz.org
09:59:40 T:3300   DEBUG: [cdART Manager] -           notify_in_background: false
09:59:40 T:3300   DEBUG: [cdART Manager] -                     recognized: 32078
09:59:40 T:3300   DEBUG: [cdART Manager] -                         remote: 32080
09:59:40 T:3300   DEBUG: [cdART Manager] -                    remotelocal: 32080
09:59:40 T:3300   DEBUG: [cdART Manager] -              replace_character: _
09:59:40 T:3300   DEBUG: [cdART Manager] -               resizeondownload: false
09:59:40 T:3300   DEBUG: [cdART Manager] -                      unmatched: 32084
09:59:40 T:3300   DEBUG: [cdART Manager] -                   unrecognized: 32083
09:59:40 T:3300   DEBUG: [cdART Manager] -             update_musicbrainz: true
09:59:40 T:3300   DEBUG: [cdART Manager] -                use_musicbrainz: true
09:59:40 T:3300   DEBUG: [cdART Manager] - sys.argv[0]:
09:59:40 T:3300  NOTICE: [cdART Manager] - Addon Work Folder: C:\Users\Joetta\AppData\Roaming\Kodi\userdata\addon_data\script.cdartmanager\
09:59:40 T:3300  NOTICE: [cdART Manager] - Addon Database: C:\Users\Joetta\AppData\Roaming\Kodi\userdata\addon_data\script.cdartmanager\l_cdart.db
09:59:40 T:3300  NOTICE: [cdART Manager] - Addon settings: C:\Users\Joetta\AppData\Roaming\Kodi\userdata\addon_data\script.cdartmanager\settings.xml
09:59:40 T:3300  NOTICE: [cdART Manager] - Addon Work Folder Found, Checking For Database
09:59:40 T:3300  NOTICE: [cdART Manager] - Addon Db not found, Must Be First Run
09:59:43 T:5752   DEBUG: ------ Window Init (C:\Users\Joetta\AppData\Roaming\Kodi\addons\script.cdartmanager\resources\skins\Default\720p\script-cdartmanager.xml) ------
09:59:43 T:5752    INFO: Loading skin file: C:\Users\Joetta\AppData\Roaming\Kodi\addons\script.cdartmanager\resources\skins\Default\720p\script-cdartmanager.xml, load type: LOAD_ON_GUI_INIT
09:59:43 T:5752   DEBUG: POParser: loaded 191 strings from file C:\Users\Joetta\AppData\Roaming\Kodi\addons\script.cdartmanager\resources\language\English\strings.po
09:59:43 T:5752   DEBUG: Previous line repeats 139 times.
09:59:43 T:5752   DEBUG: SECTION:LoadDLL(special://xbmcbin/system/ImageLib.dll)
09:59:43 T:5752   DEBUG: CGUIMediaWindow::GetDirectory ()
09:59:43 T:5752   DEBUG:   ParentPath = []
09:59:43 T:3300  NOTICE: [cdART Manager] - # Setting up Script
09:59:43 T:3300  NOTICE: [cdART Manager] - Addon Db Not Found - Building New Addon Db
09:59:43 T:3300   DEBUG: [cdART Manager] - Setting Up Database
09:59:43 T:3300   DEBUG: [cdART Manager] -     addon_work_path: C:\Users\Joetta\AppData\Roaming\Kodi\userdata\addon_data\script.cdartmanager\
09:59:43 T:3300   DEBUG: [cdART Manager] - Retrieving Album Info from XBMC's Music DB
09:59:43 T:3300   DEBUG: DialogProgress::StartModal called
09:59:43 T:3300   DEBUG: ------ Window Init (DialogProgress.xml) ------
09:59:43 T:3300   DEBUG: [cdART Manager] - jsonrpc_calls.py - Retrieving Album List
09:59:43 T:3300   DEBUG: [json_utils.py] - JSONRPC Query -
                                            {"jsonrpc": "2.0", "method": "AudioLibrary.GetAlbums", "params": { "limits": { "start": 0 }, "properties": ["title", "artist", "musicbrainzalbumid", "musicbrainzalbumartistid"], "sort": {"order":"ascending"}}, "id": 1}
09:59:43 T:3300   DEBUG: CMusicDatabase::GetAlbumsByWhere query: SELECT albumview.* FROM albumview  WHERE albumview.strAlbum <> ''
09:59:43 T:3300   DEBUG: CMusicDatabase::GetAlbumsByWhere - query took 10 ms
09:59:43 T:3300   DEBUG: [cdART Manager] - Retrieving Album Details
09:59:43 T:3300   DEBUG: [cdART Manager] - jsonrpc_calls.py - Retrieving Album Details
                                            {"jsonrpc": "2.0", "method": "AudioLibrary.GetAlbumDetails", "params": {"properties": ["artist", "title", "musicbrainzalbumid", "musicbrainzalbumartistid"], "albumid": 1}, "id": 1}
09:59:43 T:3300   DEBUG: SELECT albumview.*,albumartistview.*   FROM albumview   LEFT JOIN albumartistview ON albumview.idAlbum = albumartistview.idAlbum   WHERE albumview.idAlbum = 1   ORDER BY albumartistview.iOrder
09:59:43 T:3300   DEBUG: [cdART Manager] - jsonrpc_calls.py - Retrieving Album Path
                                            {"jsonrpc": "2.0", "method": "AudioLibrary.GetSongs", "params": { "properties": ["file", "musicbrainzalbumartistid", "musicbrainzalbumid"], "filter": { "albumid": 1 }, "sort": {"method":"path","order":"ascending"} }, "id": 1}
09:59:43 T:3300   DEBUG: CMusicDatabase::GetSongsByWhere query = SELECT songview.* FROM songview  WHERE songview.idAlbum = 1
09:59:43 T:3300   DEBUG: CMusicDatabase::GetSongsByWhere() - took 2 ms
09:59:43 T:3300   DEBUG: [cdART Manager] - Found an Artist MBID in the Database:
09:59:43 T:3300   DEBUG: Previous line repeats 5 times.
09:59:43 T:3300   DEBUG: [cdART Manager] - Found an Album Release MBID in the Database:
09:59:43 T:3300   DEBUG: [cdART Manager] - Path does not exist: 'C:\\Users\\Joetta\\Desktop\\Music\\Alabama Shakes\\Alabama Shakes - Sound & Color'
                                            {"jsonrpc": "2.0", "method": "AudioLibrary.GetAlbumDetails", "params": {"properties": ["artist", "title", "musicbrainzalbumid", "musicbrainzalbumartistid"], "albumid": 2}, "id": 1}
09:59:43 T:3300   DEBUG: SELECT albumview.*,albumartistview.*   FROM albumview   LEFT JOIN albumartistview ON albumview.idAlbum = albumartistview.idAlbum   WHERE albumview.idAlbum = 2   ORDER BY albumartistview.iOrder
                                            {"jsonrpc": "2.0", "method": "AudioLibrary.GetSongs", "params": { "properties": ["file", "musicbrainzalbumartistid", "musicbrainzalbumid"], "filter": { "albumid": 2 }, "sort": {"method":"path","order":"ascending"} }, "id": 1}
09:59:43 T:3300   DEBUG: CMusicDatabase::GetSongsByWhere query = SELECT songview.* FROM songview  WHERE songview.idAlbum = 2
09:59:43 T:3300   DEBUG: [cdART Manager] - Path does not exist: 'C:\\Users\\Joetta\\Desktop\\Music\\Avicii'
                                            {"jsonrpc": "2.0", "method": "AudioLibrary.GetAlbumDetails", "params": {"properties": ["artist", "title", "musicbrainzalbumid", "musicbrainzalbumartistid"], "albumid": 3}, "id": 1}
09:59:43 T:3300   DEBUG: SELECT albumview.*,albumartistview.*   FROM albumview   LEFT JOIN albumartistview ON albumview.idAlbum = albumartistview.idAlbum   WHERE albumview.idAlbum = 3   ORDER BY albumartistview.iOrder
                                            {"jsonrpc": "2.0", "method": "AudioLibrary.GetSongs", "params": { "properties": ["file", "musicbrainzalbumartistid", "musicbrainzalbumid"], "filter": { "albumid": 3 }, "sort": {"method":"path","order":"ascending"} }, "id": 1}
09:59:43 T:3300   DEBUG: CMusicDatabase::GetSongsByWhere query = SELECT songview.* FROM songview  WHERE songview.idAlbum = 3
09:59:43 T:3300   DEBUG: Previous line repeats 15 times.
09:59:43 T:3300   DEBUG: [cdART Manager] - Path does not exist: 'C:\\Users\\Joetta\\Desktop\\Music\\Avicii\\Avicii - True (Album)'
                                            {"jsonrpc": "2.0", "method": "AudioLibrary.GetAlbumDetails", "params": {"properties": ["artist", "title", "musicbrainzalbumid", "musicbrainzalbumartistid"], "albumid": 4}, "id": 1}
09:59:43 T:3300   DEBUG: SELECT albumview.*,albumartistview.*   FROM albumview   LEFT JOIN albumartistview ON albumview.idAlbum = albumartistview.idAlbum   WHERE albumview.idAlbum = 4   ORDER BY albumartistview.iOrder
                                            {"jsonrpc": "2.0", "method": "AudioLibrary.GetSongs", "params": { "properties": ["file", "musicbrainzalbumartistid", "musicbrainzalbumid"], "filter": { "albumid": 4 }, "sort": {"method":"path","order":"ascending"} }, "id": 1}
09:59:43 T:3300   DEBUG: CMusicDatabase::GetSongsByWhere query = SELECT songview.* FROM songview  WHERE songview.idAlbum = 4
09:59:43 T:3300   DEBUG: CMusicDatabase::GetSongsByWhere() - took 4 ms
09:59:43 T:3300   DEBUG: Previous line repeats 30 times.
09:59:43 T:3300   DEBUG: [cdART Manager] - Path does not exist: 'C:\\Users\\Joetta\\Desktop\\Music\\Avicii\\Avicii - Ultra Music Festival 2015 [2015]'
                                            {"jsonrpc": "2.0", "method": "AudioLibrary.GetAlbumDetails", "params": {"properties": ["artist", "title", "musicbrainzalbumid", "musicbrainzalbumartistid"], "albumid": 5}, "id": 1}
09:59:43 T:3300   DEBUG: SELECT albumview.*,albumartistview.*   FROM albumview   LEFT JOIN albumartistview ON albumview.idAlbum = albumartistview.idAlbum   WHERE albumview.idAlbum = 5   ORDER BY albumartistview.iOrder
                                            {"jsonrpc": "2.0", "method": "AudioLibrary.GetSongs", "params": { "properties": ["file", "musicbrainzalbumartistid", "musicbrainzalbumid"], "filter": { "albumid": 5 }, "sort": {"method":"path","order":"ascending"} }, "id": 1}
09:59:43 T:3300   DEBUG: CMusicDatabase::GetSongsByWhere query = SELECT songview.* FROM songview  WHERE songview.idAlbum = 5
09:59:43 T:3300   DEBUG: Previous line repeats 12 times.
09:59:43 T:3300   DEBUG: [cdART Manager] - Path does not exist: 'C:\\Users\\Joetta\\Desktop\\Music\\Black Eyed Peas\\Elephunk'
                                            {"jsonrpc": "2.0", "method": "AudioLibrary.GetAlbumDetails", "params": {"properties": ["artist", "title", "musicbrainzalbumid", "musicbrainzalbumartistid"], "albumid": 6}, "id": 1}
09:59:43 T:3300   DEBUG: SELECT albumview.*,albumartistview.*   FROM albumview   LEFT JOIN albumartistview ON albumview.idAlbum = albumartistview.idAlbum   WHERE albumview.idAlbum = 6   ORDER BY albumartistview.iOrder
                                            {"jsonrpc": "2.0", "method": "AudioLibrary.GetSongs", "params": { "properties": ["file", "musicbrainzalbumartistid", "musicbrainzalbumid"], "filter": { "albumid": 6 }, "sort": {"method":"path","order":"ascending"} }, "id": 1}
09:59:43 T:3300   DEBUG: CMusicDatabase::GetSongsByWhere query = SELECT songview.* FROM songview  WHERE songview.idAlbum = 6
09:59:43 T:3300   DEBUG: CMusicDatabase::GetSongsByWhere() - took 3 ms
09:59:43 T:3300   DEBUG: Previous line repeats 14 times.
09:59:43 T:3300   DEBUG: [cdART Manager] - Path does not exist: 'C:\\Users\\Joetta\\Desktop\\Music\\Black Eyed Peas\\Monkey Business'
09:59:43 T:3300   DEBUG: [cdART Manager] - XBMC Music Library does not exist, aborting database creation
09:59:43 T:3300   DEBUG: [cdART Manager] - Retrieving Local Album Artists from Database
09:59:43 T:3300   ERROR: Traceback (most recent call last):
09:59:43 T:3300   ERROR:   File "C:\Users\Joetta\AppData\Roaming\Kodi\addons\script.cdartmanager\resources\lib\database.py", line 619, in get_local_artists_db
09:59:43 T:3300   ERROR:     c.execute(query)
09:59:43 T:3300   ERROR: OperationalError: no such table: lalist
09:59:44 T:3300   DEBUG: [cdART Manager] - Retrieving Local Album Artists from Database
09:59:44 T:3300   ERROR: Traceback (most recent call last):
09:59:44 T:3300   ERROR:   File "C:\Users\Joetta\AppData\Roaming\Kodi\addons\script.cdartmanager\resources\lib\database.py", line 619, in get_local_artists_db
09:59:44 T:3300   ERROR:     c.execute(query)
09:59:44 T:3300   ERROR: OperationalError: no such table: lalist
09:59:44 T:3300  NOTICE: [cdART Manager] - Checking for artist match with fanart.tv - First Check
09:59:44 T:3300   DEBUG: DialogProgress::StartModal called (already running)!
09:59:44 T:3300   DEBUG: ------ Window Init (DialogProgress.xml) ------
09:59:44 T:3300   DEBUG: [cdART Manager] - Storing Album Artists List
09:59:44 T:3300   DEBUG: [cdART Manager] - Storing lalist
09:59:44 T:3300   DEBUG: [cdART Manager] - Finished Storing lalist
09:59:44 T:3300   DEBUG: [cdART Manager] - Counting Local Artists, Albums and cdARTs
09:59:44 T:3300   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                                self.setup_all()
                                              File "C:\Users\Joetta\AppData\Roaming\Kodi\addons\script.cdartmanager\resources\lib\gui.py", line 1048, in setup_all
                                                first_check( all_artists, local_artists )
                                              File "C:\Users\Joetta\AppData\Roaming\Kodi\addons\script.cdartmanager\resources\lib\fanarttv_scraper.py", line 356, in first_check
                                                store_fanarttv_datecode( present_datecode )
                                              File "C:\Users\Joetta\AppData\Roaming\Kodi\addons\script.cdartmanager\resources\lib\database.py", line 430, in store_fanarttv_datecode
                                                local_artist_count, album_count, artist_count, cdart_existing = new_local_count()
                                                c.execute(query)
09:59:52 T:5752   DEBUG: CApplication::ProcessMouse: trying mouse action leftclick
10:00:02 T:5752   DEBUG: Previous line repeats 1 times.
10:00:02 T:5752   DEBUG: ------ Window Deinit (Pointer.xml) ------
10:00:03 T:5752   DEBUG: CApplication::ProcessMouse: trying mouse action rightclick
10:00:03 T:5752   DEBUG: ------ Window Init (Pointer.xml) ------
10:00:08 T:5752   DEBUG: CApplication::ProcessMouse: trying mouse action leftclick
10:00:09 T:5752   DEBUG: CApplication::ProcessMouse: trying mouse action rightclick
10:00:09 T:6428   DEBUG: Thread JobWorker 6428 terminating (autodelete)
10:00:09 T:5752   DEBUG: CApplication::ProcessMouse: unknown mouse command 57361
10:00:09 T:5752   DEBUG: ------ Window Deinit (Pointer.xml) ------
10:00:10 T:5752   DEBUG: ------ Window Init (Pointer.xml) ------
10:00:10 T:5752   DEBUG: CApplication::ProcessMouse: trying mouse action rightclick
10:00:10 T:5752   DEBUG: Previous line repeats 1 times.
10:00:10 T:5752   DEBUG: CApplication::ProcessMouse: unknown mouse command 57361
10:00:10 T:5752   DEBUG: ------ Window Deinit (Pointer.xml) ------
10:00:12 T:5752   DEBUG: Keyboard: scancode: 0x0e, sym: 0x0008, unicode: 0x0008, modifier: 0x0
10:00:12 T:5752   DEBUG: CApplication::OnKey: backspace (0xf008) pressed, action is Back
10:00:12 T:6540    INFO: CActiveAESink::OpenSink - initialize sink
10:00:12 T:6540   DEBUG: CActiveAESink::OpenSink - trying to open device DIRECTSOUND:default
10:00:12 T:6540   DEBUG: CAESinkDirectSound::Initialize: Using Window handle: 3146518
10:00:12 T:6540   DEBUG: CAESinkDirectSound::Initialize: secondary buffer created
10:00:12 T:6540   DEBUG: CAESinkDirectSound::Initialize: Initializing DirectSound with the following parameters:
10:00:12 T:6540   DEBUG:   Audio Device    : Speakers (Realtek High Definition Audio)
10:00:12 T:6540   DEBUG:   Sample Rate     : 44100
10:00:12 T:6540   DEBUG:   Sample Format   : AE_FMT_FLOAT
10:00:12 T:6540   DEBUG:   Bits Per Sample : 32
10:00:12 T:6540   DEBUG:   Valid Bits/Samp : 32
10:00:12 T:6540   DEBUG:   Channel Count   : 2
10:00:12 T:6540   DEBUG:   Block Align     : 8
10:00:12 T:6540   DEBUG:   Avg. Bytes Sec  : 352800
10:00:12 T:6540   DEBUG:   Samples/Block   : 32
10:00:12 T:6540   DEBUG:   Format cBSize   : 22
10:00:12 T:6540   DEBUG:   Channel Layout  : FL,FR
10:00:12 T:6540   DEBUG:   Channel Mask    : 3
10:00:12 T:6540   DEBUG:   Frames          : 661
10:00:12 T:6540   DEBUG:   Frame Samples   : 1322
10:00:12 T:6540   DEBUG:   Frame Size      : 8
10:00:12 T:6540   DEBUG: CActiveAESink::OpenSink - DIRECTSOUND Initialized:
10:00:12 T:6540   DEBUG:   Output Device : default
10:00:12 T:6540   DEBUG:   Channel Layout: FL,FR
10:00:12 T:6540   DEBUG: CAESinkDirectSound::CheckPlayStatus: Resuming Playback
10:00:12 T:6540 WARNING: CWin32DirectSound::GetSpace - buffer underrun - W:10848, P:272, O:5288.
10:00:13 T:5752   DEBUG: Keyboard: scancode: 0x0e, sym: 0x0008, unicode: 0x0008, modifier: 0x0
10:00:13 T:5752   DEBUG: CApplication::OnKey: backspace (0xf008) pressed, action is Back
10:00:13 T:5752   DEBUG: SECTION:UnloadDelayed(DLL: special://xbmcbin/system/ImageLib.dll)
10:00:14 T:5752   DEBUG: Keyboard: scancode: 0x01, sym: 0x001b, unicode: 0x001b, modifier: 0x0
10:00:14 T:5752   DEBUG: CApplication::OnKey: escape (0xf01b) pressed, action is PreviousMenu
10:00:15 T:5752   DEBUG: WinEventsWin32.cpp: APPCOMMAND 8
10:00:15 T:5752   DEBUG: CApplication::OnAppCommand: unknown appcommand 8
10:00:15 T:5752   DEBUG: Keyboard: scancode: 0x20, sym: 0x0000, unicode: 0x0000, modifier: 0x0
10:00:15 T:5752   DEBUG: CApplication::OnKey: 0 (0xf200) pressed, action is
10:00:16 T:5752   DEBUG: Keyboard: scancode: 0x0e, sym: 0x0008, unicode: 0x0008, modifier: 0x0
10:00:16 T:5752   DEBUG: CApplication::OnKey: backspace (0xf008) pressed, action is Back
10:00:17 T:5752   DEBUG: Keyboard: scancode: 0x01, sym: 0x001b, unicode: 0x001b, modifier: 0x0
10:00:17 T:5752   DEBUG: CApplication::OnKey: escape (0xf01b) pressed, action is PreviousMenu
10:00:18 T:5752   DEBUG: Keyboard: scancode: 0x01, sym: 0x001b, unicode: 0x001b, modifier: 0x0
10:00:18 T:5752   DEBUG: CApplication::OnKey: escape (0xf01b) pressed, action is PreviousMenu
10:00:19 T:5752   DEBUG: Keyboard: scancode: 0x53, sym: 0x007f, unicode: 0x0000, modifier: 0x0
10:00:19 T:5752   DEBUG: CApplication::OnKey: delete (0xf087) pressed, action is
10:00:20 T:5752   DEBUG: Keyboard: scancode: 0x2b, sym: 0x005c, unicode: 0x005c, modifier: 0x0
10:00:20 T:5752   DEBUG: CApplication::OnKey: backslash (0xf05c) pressed, action is ToggleFullScreen
10:00:20 T:5752   DEBUG: CWinSystemWin32::SetFullScreen (windowed) on screen 0 with size 720x480, refresh 0.000000
10:00:20 T:5752   DEBUG: CWinSystemWin32::ResizeInternal - resizing due to size change (0,0,1366,768 fullscreen)->(315,114,1051,632)
10:00:20 T:5752   DEBUG: CWinEventsWin32::WndProc: window move event
10:00:20 T:5752   DEBUG: CWinEventsWin32::WndProc: window resize event
10:00:20 T:5752   DEBUG: CRenderManager::UpdateDisplayLatency - Latency set to 0 msec
10:00:20 T:5752   DEBUG: ------ Window Init (Pointer.xml) ------
10:00:23 T:5752   DEBUG: CWinEventsWin32::WndProcWindow is active
10:00:23 T:5752   DEBUG: CWinEventsWin32::WndProc: Focus switched to process C:\Program Files (x86)\Google\Chrome\Application\chrome.exe
10:00:23 T:5752   DEBUG: CAnnouncementManager - Announcement: OnQuit from xbmc
10:00:23 T:5752   DEBUG: GOT ANNOUNCEMENT, type: 8, from xbmc, message OnQuit
10:00:23 T:5752  NOTICE: Storing total System Uptime
10:00:23 T:5752  NOTICE: Saving settings
10:00:23 T:5752  NOTICE: stop all
10:00:23 T:5752  NOTICE: stop player
10:00:23 T:5752    INFO: stopping PVRManager
10:00:23 T:5752   DEBUG: CNetwork::NetworkMessage - Signaling network services to stop
10:00:23 T:5752  NOTICE: ES: Stopping event server
10:00:23 T:5752   DEBUG: CNetwork::NetworkMessage - Waiting for network services to stop
10:00:23 T:3616  NOTICE: ES: UDP Event server stopped
10:00:23 T:3616   DEBUG: Thread EventServer 3616 terminating
10:00:24 T:6304   DEBUG: Thread TCPServer 6304 terminating
10:00:24 T:1028   DEBUG: Thread PeripBusUSB 1028 terminating
10:00:24 T:888   DEBUG: Thread PeripBusCEC 888 terminating
10:00:24 T:5752  NOTICE: stop sap announcement listener
10:00:24 T:5752  NOTICE: clean cached files!
10:00:24 T:5752  NOTICE: unload skin
10:00:24 T:5752    INFO: Unloading old skin ...
10:00:24 T:5752   DEBUG: ------ Window Deinit () ------
10:00:24 T:5752   DEBUG: ------ Window Deinit (MyPrograms.xml) ------
10:00:24 T:5752   DEBUG: ------ Window Deinit (Pointer.xml) ------
10:00:24 T:5752   DEBUG: ------ Window Deinit (DialogProgress.xml) ------
10:00:24 T:5752   DEBUG: ------ Window Deinit (C:\Users\Joetta\AppData\Roaming\Kodi\addons\script.cdartmanager\resources\skins\Default\720p\script-cdartmanager.xml) ------
10:00:24 T:5752   DEBUG: CTextureBundleXBT::Cleanup - Closed bundle
10:00:24 T:5752   DEBUG: ADDON: Stopping service addons.
10:00:24 T:3764    INFO: CPythonInvoker(1, C:\Users\Joetta\AppData\Roaming\Kodi\addons\script.grab.fanart\service.py): script successfully run
10:00:24 T:5752   DEBUG: CPythonInvoker(1, C:\Users\Joetta\AppData\Roaming\Kodi\addons\script.grab.fanart\service.py): script termination took 1ms
10:00:24 T:3300    INFO: CPythonInvoker(10, C:\Users\Joetta\AppData\Roaming\Kodi\addons\script.cdartmanager\default.py): script successfully run
10:00:24 T:3764    INFO: Python script interrupted by user
10:00:24 T:3300    INFO: Python script stopped
10:00:25 T:5324   DEBUG: Library Data Provider: service version 0.0.9 stopped
10:00:25 T:5324    INFO: CPythonInvoker(2, C:\Users\Joetta\AppData\Roaming\Kodi\addons\service.library.data.provider\service.py): script successfully run
10:00:25 T:5752   DEBUG: CPythonInvoker(2, C:\Users\Joetta\AppData\Roaming\Kodi\addons\service.library.data.provider\service.py): script termination took 791ms
10:00:25 T:3300   DEBUG: Thread LanguageInvoker 3300 terminating
10:00:25 T:5324 WARNING: CPythonInvoker(2, C:\Users\Joetta\AppData\Roaming\Kodi\addons\service.library.data.provider\service.py): the python script "C:\Users\Joetta\AppData\Roaming\Kodi\addons\service.library.data.provider\service.py" has left several classes in memory that we couldn't clean up. The classes include: class XBMCAddon::xbmcgui::Window,class PythonBindings::XBMCAddon_xbmc_Monitor_Director,class PythonBindings::XBMCAddon_xbmc_Player_Director
10:00:25 T:3764   DEBUG: Thread LanguageInvoker 3764 terminating
10:00:25 T:5324    INFO: Python script interrupted by user
10:00:25 T:5324   DEBUG: Thread LanguageInvoker 5324 terminating
10:00:25 T:2268   DEBUG: Thread ActiveAE 2268 terminating
10:00:25 T:6540   DEBUG: Thread AESink 6540 terminating
10:00:25 T:5752   DEBUG: CAESinkDirectSound::Deinitialize: Cleaning up
10:00:25 T:5752  NOTICE: stopped
10:00:25 T:5752  NOTICE: destroy
10:00:25 T:5752    INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 03D3F340 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
10:00:25 T:5752    INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 04007748 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
10:00:25 T:5752    INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 04007550 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
10:00:25 T:5752    INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 04007358 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
10:00:25 T:5752    INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 040868A8 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
10:00:25 T:5752    INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 04007868 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
10:00:25 T:5752    INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 03D3F538 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
10:00:25 T:5752  NOTICE: closing down remote control service
10:00:25 T:5752  NOTICE: unload sections
10:00:25 T:7076   DEBUG: Thread RemoteControl 7076 terminating
10:00:25 T:5752  NOTICE: special://profile/ is mapped to: special://masterprofile/
10:00:25 T:5752 WARNING: Attempted to remove window 10013 from the window manager when it didn't exist
10:00:25 T:5752 WARNING: Attempted to remove window 10014 from the window manager when it didn't exist
10:00:25 T:5752 WARNING: Attempted to remove window 10015 from the window manager when it didn't exist
10:00:25 T:5752 WARNING: Attempted to remove window 10016 from the window manager when it didn't exist
10:00:25 T:5752 WARNING: Attempted to remove window 10017 from the window manager when it didn't exist
10:00:25 T:5752 WARNING: Attempted to remove window 10018 from the window manager when it didn't exist
10:00:25 T:5752 WARNING: Attempted to remove window 10019 from the window manager when it didn't exist
10:00:25 T:5752 WARNING: Attempted to remove window 10021 from the window manager when it didn't exist
10:00:25 T:5752 WARNING: Attempted to remove window 10107 from the window manager when it didn't exist
10:00:25 T:5752 WARNING: Attempted to remove window 10115 from the window manager when it didn't exist
10:00:25 T:5752 WARNING: Attempted to remove window 10104 from the window manager when it didn't exist
10:00:25 T:5752  NOTICE: application stopped...
10:00:25 T:5752   DEBUG: PVRManager - destroyed
10:00:25 T:5752   DEBUG: SECTION:UnloadDll(special://xbmcbin/system/libcurl.dll)
10:00:25 T:5752   ERROR: dllFreeLibrary - Invalid hModule specified
10:00:25 T:5752   DEBUG: SECTION:UnloadAll(DLL: special://xbmcbin/system/cpluff.dll)
10:00:25 T:5752   DEBUG: SECTION:UnloadAll(DLL: special://xbmcbin/system/libcec.dll)
This line indicates you're not running my fork. It won't work if you installed the addon via the Addon-Repo.
Try to uninstall the Addon (again) and install the ZIP-Version - carefully follow this: http://forum.kodi.tv/showthread.php?tid=...pid1893252
(2015-06-30, 16:47)stef.an Wrote: [ -> ]
This worked! Sorry I missed it. Thank you
I never could make this addon to automatically download Music Artist/Album fanart for my songs in the background. Could someone please help me to get this addon to work correctly? I already installed the latest version of the addon manually (but didn't make any difference). No matter what I do, cdART doesn't appear to do anything at all.
Below is the log while trying to start CDart addon manually (In Kodi, I search for the addon and start it that way). I noticed there was an error with the database file in my Kodi log. I have already deleted that file and restarted Kodi. It seems like it get's created automatically; but, this addon can't do anything with it. Maybe, that's just a symptom to the real issue. Thanks in advance!
cdART - errors when trying to start
This addon is not intended to do anything automagically in the background. It is a manually started mass downloader as mentioned in reply to your older posts.
Your logfile
08:44:02 T:8612   ERROR: Traceback (most recent call last):
08:44:02 T:8612   ERROR:   File "C:\Users\MKANET\AppData\Roaming\Kodi\addons\script.cdartmanager\default.py", line 482, in <module>
08:44:02 T:8612   ERROR:     c.execute(query)
indicates you're not running my fork, it would be line 483 otherwwise. It won't work if you installed the addon via the Addon-Repo.
(2015-06-24, 17:03)stef.an Wrote: [ -> ]"supported" is a matter of opinion - if you talk about compatibility updates: Yes, I'm still here and I still use the plugin, so I'll update it and publish the changes if needed Smile
Considering Giftie seems to have fallen off the face of the planet since the Helix release, I'd say "Go for it". This add-on is pretty much an essential, and I personally don't see Martijn adding the features contained in cdART Manager to Artwork Downloader while there is a chance that either Giftie may return, or as is the case, someone else has taken up the mantle.
Considering this isn't the first time the baton has changed hands either with this add-on, or others on Kodi, you should have no reservations about doing so if that's what you want to do. But be wary of promising to support this if at a later date you decide that's not an option any longer.
Personally, while I like cdART Manager for it's features and what it brings to the table, it's use and UI is a bit clunky, and dated. There are also options which are vague and unclear as to what their purpose is to someone new to the addon. This is the area that could use the most improvement. Also, the fact that once you initiate a scan you are "tied-in" to the UI and cannot do anything else in Kodi, is less than desirable (given the length of the scans in certain cases).
I for one would be very interested in testing anything you manage to cook up in the future.
Smile
