I've been trying to install cdArt Manager for a few hours now and as soon as the plugin is installed, it freezes my Kodi.
from poking around in the logs and the code, it looks like some unintitalized db tables:
21:46:06 T:140118711056128 NOTICE: [cdART Manager] - ############################################################
21:46:06 T:140118711056128 NOTICE: [cdART Manager] - # cdART Manager #
21:46:06 T:140118711056128 NOTICE: [cdART Manager] - # default.py module #
21:46:06 T:140118711056128 NOTICE: [cdART Manager] - # script.cdartmanager #
21:46:06 T:140118711056128 NOTICE: [cdART Manager] - # Giftie #
21:46:06 T:140118711056128 NOTICE: [cdART Manager] - # 4.0.5 #
21:46:06 T:140118711056128 NOTICE: [cdART Manager] - # Ppic, Reaven, Imaginos, redje, Jair, #
21:46:06 T:140118711056128 NOTICE: [cdART Manager] - # Chaos_666, Magnatism, Kode, Martijn #
21:46:06 T:140118711056128 NOTICE: [cdART Manager] - # Thanks for the help guys... #
21:46:06 T:140118711056128 NOTICE: [cdART Manager] - # Frodo #
21:46:06 T:140118711056128 NOTICE: [cdART Manager] - Looking for settings.xml
21:46:06 T:140118711056128 NOTICE: [cdART Manager] - Addon Work Folder: /home/xbmc/.kodi/userdata/addon_data/script.cdartmanager/
21:46:06 T:140118711056128 NOTICE: [cdART Manager] - Addon Database: /home/xbmc/.kodi/userdata/addon_data/script.cdartmanager/l_cdart.db
21:46:06 T:140118711056128 NOTICE: [cdART Manager] - Addon settings: /home/xbmc/.kodi/userdata/addon_data/script.cdartmanager/settings.xml
21:46:06 T:140118711056128 NOTICE: [cdART Manager] - Addon Work Folder Found, Checking For Database
21:46:06 T:140118711056128 NOTICE: [cdART Manager] - Addon Db Found, Checking Database Version
21:46:06 T:140118711056128 NOTICE: [cdART Manager] - Looking for database version: 3.0.3
21:46:06 T:140118711056128 ERROR: Traceback (most recent call last):
21:46:06 T:140118711056128 ERROR: File "/home/xbmc/.kodi/addons/script.cdartmanager/default.py", line 485, in <module>
21:46:06 T:140118711056128 ERROR: if version[0][0] == __dbversion__:
21:46:06 T:140118711056128 ERROR: IndexError: list index out of range
21:46:06 T:140118711056128 NOTICE: [cdART Manager] - # Error: IndexError
21:46:06 T:140118711056128 NOTICE: [cdART Manager] - Trying To Delete Database
21:46:09 T:140118711056128 NOTICE: [cdART Manager] - # Setting up Script
21:46:09 T:140118711056128 NOTICE: [cdART Manager] - Addon Db Not Found - Building New Addon Db
21:46:09 T:140118711056128 ERROR: Traceback (most recent call last):
21:46:09 T:140118711056128 ERROR: File "/home/xbmc/.kodi/addons/script.cdartmanager/resources/lib/json_utils.py", line 28, in retrieve_json_dict
21:46:09 T:140118711056128 ERROR: json_dict = result[items]
21:46:09 T:140118711056128 ERROR: KeyError: 'albums'
21:46:09 T:140118711056128 NOTICE: [json_utils.py] - retrieve_json_dict - JSONRPC -
{'jsonrpc': '2.0', 'id': 1, 'result': {'limits': {'start': 0, 'total': 0, 'end': 0}}}
21:46:09 T:140118711056128 NOTICE: [json_utils.py] - retrieve_json_dict - Error trying to get json response
21:46:09 T:140118711056128 ERROR: File "/home/xbmc/.kodi/addons/script.cdartmanager/resources/lib/database.py", line 619, in get_local_artists_db
21:46:09 T:140118711056128 ERROR: c.execute(query)
21:46:09 T:140118711056128 ERROR: OperationalError: no such table: lalist
21:46:09 T:140118711056128 NOTICE: [cdART Manager] - Checking for artist match with fanart.tv - First Check
21:46:09 T:140118711056128 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <class 'sqlite3.OperationalError'>
Error Contents: no such table: counts
File "/home/xbmc/.kodi/addons/script.cdartmanager/resources/lib/gui.py", line 71, in onInit
self.setup_all()
File "/home/xbmc/.kodi/addons/script.cdartmanager/resources/lib/gui.py", line 1048, in setup_all
first_check( all_artists, local_artists )
File "/home/xbmc/.kodi/addons/script.cdartmanager/resources/lib/fanarttv_scraper.py", line 356, in first_check
store_fanarttv_datecode( present_datecode )
File "/home/xbmc/.kodi/addons/script.cdartmanager/resources/lib/database.py", line 430, in store_fanarttv_datecode
local_artist_count, album_count, artist_count, cdart_existing = new_local_count()
File "/home/xbmc/.kodi/addons/script.cdartmanager/resources/lib/database.py", line 718, in new_local_count
c.execute(query)
OperationalError: no such table: counts
