Tried installing smbclient, and this was the result:
root@XBMCLive:~# apt-get install smbclient
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following extra packages will be installed:
samba-common samba-common-bin
Suggested packages:
smbfs
The following NEW packages will be installed:
samba-common samba-common-bin smbclient
0 upgraded, 3 newly installed, 0 to remove and 0 not upgraded.
Need to get 16.7MB of archives.
After this operation, 48.2MB of additional disk space will be used.
Do you want to continue [Y/n]? y
Err
http://security.ubuntu.com/ubuntu/ lucid-updates/main samba-common 2:3.4.7~dfsg-1ubuntu3.4
404 Not Found
Err
http://archive.ubuntu.com/ubuntu/ lucid-updates/main samba-common 2:3.4.7~dfsg-1ubuntu3.4
404 Not Found [IP: 91.189.88.31 80]
Err
http://archive.ubuntu.com/ubuntu/ lucid-updates/main samba-common-bin 2:3.4.7~dfsg-1ubuntu3.4
Err
http://archive.ubuntu.com/ubuntu/ lucid-updates/main smbclient 2:3.4.7~dfsg-1ubuntu3.4
Failed to fetch
http://archive.ubuntu.com/ubuntu/pool/ma....4_all.deb 404 Not Found [IP: 91.189.88.31 80]
Failed to fetch
http://archive.ubuntu.com/ubuntu/pool/ma...4_i386.deb 404 Not Found [IP: 91.189.88.31 80]
Failed to fetch
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
