(2012-10-21, 13:34)megaskywarp Wrote: [ -> ]fellas I'm not sure what I did, but an hour ago I had 600 artists, 1000 discs, and 1000 arts, and now I have 0, 0, 0 and I can't figure out what I'm supposed to do. Is there a way to point the manager to my music directory? I'm not sure what the difference is between Update XBMC's Music Database and Update Database in Modify Local Database?
Any help would be greatly appreciated. Thanks very much!
First off, make sure you are using the version available on the first page(2.7.5). If you are using an earlier version, upgrade then follow the instructions below the link.
Update XBMC's Music Database --- this updates XBMC's actual music database
Modify Local Database -> Update Database --- This updates the Addon's database(useful when you add music to XBMC)
Thanks giftie. I started running "Update Database" about six hours ago and I'm almost at 50% (should it take this long?) It definitely is scanning my albums/artists and I'm keeping my fingers crossed.
The time depends on how big your XBMC Music Library is, how many things need to be updated and how easily the info matched with MusicBrainz.
Hi giftie,
I want to thank you for your script and to ask if you can help me. I'm using cdart art manager for quite some time always without problems... some weeks ago it stoped working (I'm building a new xbmc version from git each friday and have installed the script version 2.7.5). What I see at the moment is when I start cdartmanager a dialog which seems to scan through my musicdatabase(I can see all of my artists). Once finshed there are no entries at the bottom, sometimes it says zero sometimes it is blank. When I try to start an automatic download nothing happens, when i try to manually download something the script hangs upon the creation of the artist list. As you have written in the post #1272 there should be a l_cdart.db in the userdata/addon_data/script.cdartmanager folder but in my case there is no such file. For me it seems like that the script isn't able to create the database file and I don't know why... I've tried already the hints that you gave to other users... nothing has worked.
If the problem is my nightly version of xbmc, I will be patient and wait for your next release.
Keep up your great work!
(2012-10-21, 20:08)lostwithouthope Wrote: [ -> ]Hi giftie,
The problem is the fact you're using the Development version of XBMC, there have been changes made after I release 2.7.5. The next version does have these things fixed.
Hi giftie,
I tried yesterday the use of custon label colours. After I had enabled the option only the first artist was displayed in the artist llist. After disabling the option all works fine again.
When I update the addon database and checking the new items was done the script checks all MBIDs. Checking of the MBIDs during update is disabled in the settings. Please have a look at this. Thanks.
I'm probably just not looking in the right place but you said the addon can be used by skins etc. Is there a list of params I can pass to it?
Ta.
(2012-10-23, 19:59)samurai07 Wrote: [ -> ]Hi giftie,
Thanks for the report. Will look into the problem
Quote:When I update the addon database and checking the new items was done the script checks all MBIDs. Checking of the MBIDs during update is disabled in the settings. Please have a look at this. Thanks.
I did catch this and it is fixed in the upcoming release
(2012-10-23, 20:02)Mizaki Wrote: [ -> ]I'm probably just not looking in the right place but you said the addon can be used by skins etc. Is there a list of params I can pass to it?
Ta.
At the moment the following background modes are available:
autocdart <- Auto download Album cdARTs
autocover <- Auto download Album cover Artwork
autofanart <- " " Artist Fanart
autologo <- " " Artist clearLogos
autothumb <- " " Artist Thumbs
autoall <- " " All artwork
database <- Build the script's database
update <- Update the script's database
There will be the oneshot mode will come it the future(especially with my PR's that have been pulled in that help)
RunScript(script.cdartmanager,mode)
Eg: RunScript(script.cdartmanager,autoall) <- starts the script downloading everything in the background
Hi, When new version of cdART will be released?
I've only tried "update" via JSONRPC
{"jsonrpc": "2.0", "method": "Addons.ExecuteAddon", "params": { "wait": false, "addonid": "script.cdartmanager", "params": [ "update" ] }, "id": 2}
but there is an error in your JSON request:
12:47:05 T:2897288000 DEBUG: JSONRPC: Incoming request: {"jsonrpc": "2.0", "method": "AudioLibrary.GetSongs", "params": { "properties": ["file", "musicbrainzalbumartistid"], "filter": { "albumid": 181 }, "sort": {"method":"fullpath","order":"ascending"} }, "id": 1}
12:47:05 T:2897288000 DEBUG: JSONRPC: Calling audiolibrary.getsongs
12:47:05 T:2897288000 DEBUG: JSONRPC: Value does not match any of the enum values in type method
12:47:05 T:2897288000 DEBUG: JSONRPC: Invalid property "method" in type sort
Should that be: "sort": {"method":"file","order":"ascending"} ?
(2012-10-27, 13:54)Mizaki Wrote: [ -> ]I've only tried "update" via JSONRPC
That is correct.. The next release has this fixed, sometimes it's hard keeping up with Montellese.. I hope to have the next release out today(maybe pushing it to the repo for everyone..) h
Found the problem.. The colour names were being translated and this caused XBMC not to recognize the names. This will be fixed in the next version
Good news. Awaiting the new version...
I don't know if you've fixed this one already. Downloading a single album cover:
Error Type: <type 'exceptions.NameError'>
Error Contents: global name 'pDialog' is not defined
File "/home/bob/.xbmc/addons/script.cdartmanager/resources/lib/gui.py", line 1240, in onClick
message, d_success, is_canceled = download_art( url, cdart_path, database_id, "cover", "manual", 0 )
File "/home/bob/.xbmc/addons/script.cdartmanager/resources/lib/download.py", line 205, in download_art
pDialog.close()
NameError: global name 'pDialog' is not defined
Also, is it possible to give an artist name or MBID for auto run? So: autoall/autocover?<artist name/MBID/album name/release id>
I'm looking to integrate it the same as artwork downloader so people can just click a button on an artist's info or album page.
