Full Version: VDPAU + HTS TVHeadend
Hi
VPDAU stoped working when I changed pvr client from VDR-VNSI to HTS TVHeadend. Every thing is the same but switch from one addon to another makes vdpau not working.
On VDR-VNSI is working well even for MPEG2 streams and on feature C nVidia card (GT220).
In the log I can see that frame info (width/height) is not detected and as far as I remember it already corrected (some delay added) even before 30871rev. version.
Is there anyone with HTS + VDPAU working well ?
xbmc: pvr-testing-36~yavdr-karmic30871+6 (the same on: 1:9.11+svn30781.karmic5)
20:43:18 T:3077683072 M:779702272   DEBUG: ------ Window Init (DialogBusy.xml) ------
20:43:18 T:3077683072 M:779702272   DEBUG: Alloc resources: 0.01ms (0.00 ms skin
load)
20:43:20 T:2945293168 M:775782400   DEBUG: AddOnLog: xbmc.pvrclient/HTS-TVHeaden
d Client: cHTSPDemux::SubscriptionStart - id: 3, type: CA, language: (null)
d Client: cHTSPDemux::SubscriptionStart - id: 2, type: AC3, language: pol
d Client: cHTSPDemux::SubscriptionStart - id: 1, type: H264, language: (null)
20:43:20 T:2945293168 M:775782400   DEBUG: CDatabase: Connecting to database MyT
V4.db at /home/htpc/.xbmc/userdata/Database:
20:43:20 T:2945293168 M:775782400   DEBUG: Open - TV Channel has started on file
name pvr://channels/tv/all/48.pvr
20:43:20 T:2945293168 M:775782400  NOTICE: Creating Demuxer
20:43:20 T:2945293168 M:775782400   DEBUG: CDVDDemuxPVRClient::RequestStreams():
added stream 0:2 with codec_id 86020
added stream 1:1 with codec_id 28
20:43:20 T:2945293168 M:775782400  NOTICE: Opening video stream: 1 source: 256
20:43:20 T:2945293168 M:775782400  NOTICE: Creating video codec with codec id: 2
8
20:43:20 T:2945293168 M:775782400   DEBUG: CDVDFactoryCodec: compiled in hardwar
e support: CrystalHD:yes OpenMax:no VDPAU:yes VAAPI:yes
20:43:20 T:2945293168 M:775782400   DEBUG: FactoryCodec - Video:  - Opening
20:43:20 T:2945293168 M:775782400  NOTICE: CDVDVideoCodecFFmpeg::Open() Creating
VDPAU(0x0, 28)
20:43:20 T:2945293168 M:775782400 WARNING: (VDPAU) no width/height available, ca
n't init
20:43:20 T:2945293168 M:775782400  NOTICE: CDVDVideoCodecFFmpeg::Open() Failed t
o get VDPAU device
20:43:20 T:2945293168 M:775782400  NOTICE:  (VDPAU) Close
20:43:20 T:2945293168 M:775782400  NOTICE: CDVDVideoCodecFFmpeg::Open() Using co
dec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
20:43:20 T:3056597872 M:775782400   ERROR: PVR: HTS-TVHeadend Client/127.0.0.1:9
982 - Client returns bad error (-3) after SignalQuality
20:43:20 T:2945293168 M:775782400   DEBUG: FactoryCodec - Video: ff-h264 - Opene
d
20:43:20 T:2945293168 M:775782400  NOTICE: Creating video thread
Regards
Janusz
It's a known but already fixed issue. You'll have to update both, XBMC and TVheadend, in order to regain hardware acceleration.
Please use the search function before posting as this was covered multiple times before.
Thanks,
have seen it but only for vdr-vns/streamserveri only.
Regards
Janusz
