2010-07-17, 22:57
Is it possible to select DVD or AIR ordering per show located in the same "source"?
For example:
C:\Tv-Shows\Battlestar Galactica 1978 <--- Broken DVDRIP that needs AIR ordering for proper scraping
C:\Tv-Shows\Firefly <--- DVDRIP that needs DVD Order for scraping
C:\Tv-Shows\The Wire <--- AIR/DVD order is same, so doesn't matter
Currently the only way I've found is to change the directory structure to
C:\Tv-Shows\AIR-Order\Battlestar Galactica 1978
C:\Tv-Shows\DVD-Order\Fiirefly
C:\Tv-Shows\DVD-Order\The Wire
And add AIR-Order as one source and DVD-Order as another source... but I'd rather not do that because its sooo ugly...
An entry in the .nfo file would be kind of neat..
EDIT: TheTVDB scraper..
For example:
