2010-07-18, 14:45
Hi guys,
I'm hoping someone can clear up the behavior of this for me. I tried a search and the wiki but didn't see anything definitive.
I have three profiles, each with a different skin. If I set the first two skins to use a skin-custom view type and the last skin to use a simple list (and do this in any order), by the time I return to the first skin it view type has reverted to a list view. Switching profiles itself isn't an issue so long as I don't change the view preferences (even if I change back to the one I entered with it will 'break' the setting for the other profiles).
So I guess the question is, should you be able to have different skin-specific settings across profiles, or is the behavior described above expected?
Thanks for any & all info.
