2010-07-20, 14:09
Hey there,
I wanted to contribute something here, since you guys really helped us with our XBMC-Setup.
So, here’s a guide to setting up Logitech Harmony for XBMC.
Notes:
- I’m not going to reinvent the wheel here, though being German, I probably could.
- I’m sure everything in this guide has been done and explained before; I just wanted to make it more beginner friendly.
- All suggestions are quite welcome, just drop me a pm, or better: post here, I’m happy to include good ideas.
- Our living room isn't that nice yet. We just moved in. Suck it.
So, let’s get started:
(1) Requirements
You’ll probably need:
- A fully set up XBMC installation (probably got that already
- Some sort of Harmony Remote (probably got that, too)
- An infrared Receiver (RC6-capable)
Maybe a picture will help:
(2) The receiver
Any RC6 capable receiver will do, we’ll use an HP Media Center receiver, since it’s cheap and easy to get on eBay.
The RC6 point is especially important, as non-RC6 ones won't work with your Harmony.
On a side note: My receiver is from an eBay-Guy in Hong Kong, delivery to Germany took 3 days, so that's fine.
(3) The remote
You probably already have one, if not, you should go for one with a display, the smaller models mostly differ in how
many devices you can control. You’ll need 2 devices for XBMC. We’ll be using our 555 model.
(4) The setup process
Plug the RC6-IR-Receiver into your XBMC. You’ll want a line of sight connection to your couch.
Start the setup for your Harmony Remote as usual and configure all of your devices except for the media center.
(5) Now let’s get to the configuration of the MC profile
Start the Logitech Harmony Remote Software. In the devices tab, click ‘Add Device’
Select: Computer – Media Center PC – Microsoft – “Windows Media Center”
You’ll have to enter the last bit by hand.
Add this as a device and name it MCE Remote.
Now, repeat the ‘Add Device’ process, this time select:
Computer – Media Center PC – Microsoft – “MCE Keyboard”
Add this device and name it MCE Keyboard
The missing images above, along with additional notes by jjd-uk, may be seen here
Notes:
(1) Requirements
(2) The receiver
(3) The remote
