Looks nice and probably works good however, at least two issues would keep me from using this. No command line and no ability to specify more than one hard drive. From looking through the discussion forum I gather that my second point is accurate? Any plans to inplement these features?
Thanks,
Mark
mwkurt Wrote:Looks nice and probably works good however, at least two issues would keep me from using this. No command line and no ability to specify more than one hard drive. From looking through the discussion forum I gather that my second point is accurate? Any plans to inplement these features?
Thanks,
Mark
Next Release is going to support multiple folders for TV Series/Movies. Its under development. Post your reviews, comments and issues at
http://tvscout.codeplex.com. It would be difficult to track the same on forums.
New release is available for download
Hello,
Nice for trying to create a media manager software.
However, I have some issues to report. I am currently unable to change any settings. Not sure this is doe to my using a custom style, or what. When will a new release be out?
Also, please make sure you take a look at this:
http://msdn.microsoft.com/en-us/library/...S.85).aspx
Windows Application UI Development
I guess you love glass and all that, but in small portions. Maybe you could take a look at the Ribbon support for WPF:
http://blogs.msdn.com/b/wpf/archive/2010...r-wpf.aspx
All in all, thanks for the work
mediascout 3.0 preview 3 released
Updates is always welcome
cool program - like the fact that it supports wmc & xbmc together - couple of suggestions though
allow user limitation for backdrops - maybe you want 5 or 10 different backdrops - not all or 1 (some shows have over 40 backdrops on tmdb/tvdb
if there are multiple instances of a show, allow user to decide which one to choose.
if metadata exists for xbmc or wmc don't query tmdb/tvdb for info. i have a lot of shows i have made up my own metadata for, whether they are Joan and jimmy's wedding video or an independent film release, not on tmdb, I made metadata for manually with an old version of metabrowser which only supports wmc. and wanted to convert this info for xbmc, but cannot as media scout will not read the metadata and thus cannot find the relevant info
(2013-01-20, 16:14)cijah Wrote: [ -> ]cool program - like the fact that it supports wmc & xbmc together - couple of suggestions though
this post has been dead for 2-3 years please check dates before posting.
