2010-07-22, 20:00
I have XBMC live installed on the HDD. When I go to te shutdown menu and select shutdown, all is ok and pc is switched off.
But when I select sleep mode or hibernation, pc goes to the black screen with blinking cursor. CTRL + ALT + F1 is working, I can see a login, but that's all, I can't insert any name.
I tried to change setting in xbmc/setting/power saving/shut_down_function from default shut down to sleep or hibernate, but with this set-up I can't shutdown pc also not switch to sleep and also not switch to hibernate mode - pc always jump to black screen with blinking cursor.
What I must change I xbmc live to get working sleep mode ?
thanks
Alda
thanks
Alda
