Full Version: Max resolution and min Specs
Hello !
First of all i have to thank you for this wonderful software, i'm currently using it with a HTC Desire and it works flawlessly (using XBMC Dharma SVN) ! Big Grin
I'm interested in buying a Archos 8 Home Tablet which runs on Android 1.5 with a 800x600 resolution, to make it a nice control remote for my xbmc boxes and all my Home Automation system (using local website). It sells at 149€ so it's not very expensive and could be useful and replace some tactile monitor..
So that is my question, what are the minimal specs for the app to run smoothly and what is the upper resolution supported (I know my phone is 800x480 so it should be close..).
I have read that you do not plan to modify your app for Android tablet, but I give it a try anyway..
Thank you very much for all your hard work !
