Hi, I'm looking for some direction to get Aeon into XBMC. I've read the wiki and searched round the forums but I'm still not clear on the procedure. Any help is appreciated.
ATV 3.0.2
XBMC 9.11
SVN 31938
Thanks, Daniel
Download + Copy to Skin Folder. Select Skin in Appearance settings. Done & Done.
If that does'nt help you you hav to go a bit deeper in detail
kidnetic Wrote:XBMC 9.11
SVN 31938
Which one?
SVN 31938
Which is it to be? THey are both different versions and support skins in different ways.
Not sure i wouldn't bother with aeon on the atv, might stuggle with some of the fanart.
I'm using SVN 31938. I tried to find the skin folder in atv directory but was unable to.
I like the polished look of Aeon but it sounds like atv may not have the horsepower to run it reliably. Is that the case? Can anyone suggest another apart from confluence to try?
Thanks for the replies, Daniel
kidnetic Wrote:I tried to find the skin folder in atv directory but was unable to.
me too!! im just about going crazy trying to install this!!
Where is the skin folder gone in the new version ?!?
thank you
all sorted now
