Full Version: Kiosk Mode
Beautiful skin Jeroen.
Would you consider making some of the home menu items user selectable in skin settings and then implementing a kiosk mode? This makes it easier once it is setup correctly to keep others from accidentally changing a viewtype.
Thanks for all your work with XBMC.
Sure, I'd be interested in implementing this. I'll put it on my todo list. It's probably going to have to wait until at least 0.9 though.
Its pretty easy to implement - just modify this a little to fit your skin (which I pulled from aeon in the first place):
http://forum.xbmc.org/showthread.php?tid=70655
