Full Version: Translate of addon with upstream repo existing
Pages: 1 2 3
well this appears to be working:
xml2po -o template.pot template.xml
xml2po -p LANG.po -o LANG.xml template.xml
ventech Wrote:well this appears to be working:
You have tried it with sample files ?
yes
ventech Wrote:yes
Could you please enclose the sample files, for checking ?
This works really well and easy.
At the end i get back the original xml file format only the translated parts show up as changed strings.
I was even made a test with a modified original xml file. With poedit (but i am sure launchpad also nows this function) i was able to make an update and the changed new strings appeared, the deleted strings disappeared with no problem. At the end i once again got back the correct translated xml file.
The only think to keep things maintained is to create the po template (pot) file from time to time using the current strings.xml files in svn or git and i guess upload to launchpad.
What do you think Spiff ? This could work out.
Can we make a test on xbmc launchpad ?
this looks promising. i'll discuss with those with the access needed.
alanwww1 Wrote:The only think to keep things maintained is to create the po template (pot) file from time to time using the current strings.xml files in svn or git and i guess upload to launchpad.
actually, launchpad can automatically import from bazaar branches
@Ventech
Thanks for the great suggestion with po2xml ! Big Grin
ventech Wrote:actually, launchpad can automatically import from bazaar branches
But doesn't Launchpad needs po or pot file for direct import ? In this case the developers would always have to keep a po file in their repositories.
Anyway in the worst case the xml files could be converted and moved to launchpad manually by anybody who can undertake this task.
it's not rocket science to script it.
alanwww1 Wrote:But doesn't Launchpad needs po or pot file for direct import ? In this case the developers would always have to keep a po file in their repositories.
either; the person who adds a string also adds it to the .pot file, or you have a script that executes xml2po. i think the latter is the best because then you can export from launchpad too.
this way all files will stays synced. at least in theory..
spiff Wrote:this looks promising. i'll discuss with those with the access needed.
Any news on this ?
Hi, folks!
I'm also interested in a solution that makes everyone's job easier.
On my latest trac ticket with dharma-pre plugins translations, @spiff alerted me about the problem with the upstream versions of some addons. A git patch is cool, but he had to separate my plugins patch between addons with and without upstream version/svn/git... (and because I didn't realized it before, I made is work harder... sorry spiff).
And I agree that it may cause confusion and chaos maintaining a record of what was translated and what wasn't.
I know that apart from confluence and xbmc strings, I already translated scrapers and plugins. But because some weren't merged, my records are somewhat confusing and in need of a git code review to stay updated on work done.
So, in short, I'm all for a centralized translation system/tool/whatever.
One suggestion I read on the forums was an online community translation tool/site with someone responsible for a language (one person per language) to maintain all things tied together and review/approve translations for that language . I can be responsible for pt_PT. AFAIK, I'm the only PT translator for the last 1 1/2 years.
Anyway, I'm gonna continue translating to update dharma as best has I can.
Happy coding.
Cris
Might not be as straight forward as it appeared.
When trying to convert the xml files to po files, you get duplicates
.pot:
#: en.xml:27(string) en.xml:48(string)
msgid "May"
msgstr ""
.po produced using xml2po -o no.po -r no.xml en.xml
msgid "May"
msgstr "Mai"
msgid "May"
msgstr "mai"
and this translation (capital and lowercase 'm') actually makes sense. This is what you get for building a sentence word by word instead of using a single formated string; so there's a lot of work to do.
Work that we're most grateful for! The weather stuff is nasty as we're converting it token (word) by token (word).
Ideally we shouldn't be trying to translate the weather stuff at all - it's never going to work perfectly as we're always going to be missing some strings.
Pages: 1 2 3
