Full Version: change subtitle offset OSD position
The problem of this dialog is that it's just above the subtitles, making very difficult to adjust the offset.
Is there any way to change the postiion? I know I can change the subtitles postition, but I'm too used to read them at the bottom of the screen
I have search the forum and the skin sources, I found nothing, isn't this a common problem?
Thank you
this was changed in r30372.
