Full Version: Help with Transparency! library mode!!!
Ok, I installed the newest xbmc live disk as a stand alone on my hard drive, then I added the newest Transparency! skin. I am having a problem with library mode in my "Movies" screen. Every time i enter the movies screen, my movies are in library mode! I change it back to file mode; but when I go back to the main screen, re-start xbmc, or otherwise leave my movies screen, it reverts to library mode! this is driving me nuts! and yes, i tried toggling settings/ skin settings/ home window/ Videos menu - use file mode on and off, it made no difference.
could you tell me which version of xbmc and Transparency! you're using.
i need revision numbers, 'newest' doesn't mean anything in my book. ;-)
