2010-07-27, 13:15
OK i've installed xbmcfreak 9.11 v15 to the harddrive and boot from it. Everything works perfectly and i'm able to play movies with no stutter across my network.
Now the issue comes when i log in via FTP to update a few things.
I've been trying to get my remote to work fully (most buttons work fine) and have discovered a solution but then hit a brick wall.
My remote is a Emprex 3009URF and i followed this guide to get the extra buttons to work
http://forum.xbmc.org/showpost.php?p=550...stcount=37
OK so created the file, ftp'din to find XBMC directory is read only. OK no prob, i just need to login with username / password as xbmc instead of the one live asked me to create. Nope, xbmc doesn't exist. Bugger, ok, i'll put that file in my ~home directory and reboot, that should work. Nope ok ok so i go into a shell in putty and do as others suggest here and sudo passwd root it asks for my password
ARGHHHHHHHHHHHHH. ok lets continue looking, try search and eventually find
that sounds like a workable idea.
ARGHHHHHHHHHHH. OK no idea how to proceed and write to that directory. Fine, its likely me so i'll move on to try something else.
Having popcorn hour c200 on the same network i want to share these media files in xbmc. No problem each has fanart, poster and nfo. However due to Aeon skin in yamj handling badly i use in nfo's.
Now XBMC skins don't like and i end up with no plot or outline at all as i don't have in the nfos.
Right, back to searching and eventually find i can replace plot with outline in the skins
Great, so i ftp in, grab the file, edit, try to reupload and BAM, read only file system again. Oh no, not again
Ok so i'll put it my ~home directory under .xbmc/skins, that will work. Guess what, yes your starting to see a pattern here, my ~home directory ~danz0l/.xbmc/skin folder is read only too.
So now i'm at a loss. Is it me, the xbmcfreak distro or something i need to change ? I really need help here guys.
[sudo] password for danz0l:
Enter new UNIX password:
Retype new UNIX password:
passwd: Authentication token manipulation error
passwd: password unchanged
danz0l@unknown90fba6876a78:~$
Quote:log in via SSH and change the permissions on the file or folder you are trying to write to to 775
sudo chmod -R 775 [directory]
if that doesn't work try 777
danz0l@unknown90fba6876a78:/home$ sudo chmod -R 775 xbmc
chmod: changing permissions of `xbmc': Read-only file system
chmod: changing permissions of `xbmc/.profile': Read-only file system
chmod: changing permissions of `xbmc/.bash_logout': Read-only file system
chmod: changing permissions of `xbmc/.bashrc': Read-only file system
<plot></plot>
<outline></outline>
<plot></plot>
Quote:I'm using xbmc live - not windows, but I was after the same thing when in Library mode using mediainfo 2 view. Following the suggestions on this thread did the trick (changing ListItem.Plot to ListItem.Plotoutline). In my case I modified the ViewsVideoLibrary.xml file found in /usr/share/xbmc/skin/Confluence/720p
