2010-07-27, 19:09
Hi All
Hope someone can help!!
I have been running XBMC in windows vista 32bit and almost everytime i start playing an album (from sources, dont use library mode) then minimize xbmc either using windows start key or ALT+Tab after the particular track that is playing on minimize xbmc doesnt play the next track and i cant restore xbmc to full window (it crashes) my only option is to force end task and restart xbmc.
I have just reinstalled my computer and reverted back to XP Pro (this is due to other ATI Multiple display issues, forcing 29hz) and i am still experiencing the same crash issue.
Any thoughts/fixes on this would be appreciated.
I know XBMC is more obviously designed to be run maximised being a media center, but i still think it should be useable in a minimized state
thanks
thanks
