Full Version: Wakeup headache...
Hello folks Cool
I hope very much that someone could help me out with my endless pain. Confused
I have made myself a HTPC and in January 2010 I have installed Ubuntu 9 and at that time I couldn't fix few issues so I switched in Windows. Nevertheless, this was a pain and as such, this month I have reformated the drive that hold only the OS and installed the Ubuntu 10.04.
I have installed XBMC, LIRC and after days of readings I managed that it suspends nicely after the set time, it works nice with the MCE remote, including the Power button that suspends the system.
The problem and my biggest headache is that I can not make it to wake up from remote.
It wakes up from mouse and keyboard but not from remote.
I have followed few procedures found here in wiki.XBMC, ubuntu forums and other sources.
My current config shows:
The remote is Topseed Tech...
Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
[b]Bus 006 Device 002: ID 1784:0008 TopSeed Technology Corp. [/b]
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 002: ID 046d:c510 Logitech, Inc. Cordless Mouse
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 006: ID 152d:2339 JMicron Technology Corp.
Bus 002 Device 005: ID 05ac:0220 Apple, Inc. Aluminum Keyboard
Bus 002 Device 004: ID 05ac:1006 Apple, Inc. Hub in Aluminum Keyboard
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
and wake up devices are set in rc.local. I have enabled all USB ports to make sure that other devices like mouse and keyboard wakes up the computer.
Device    S-state      Status   Sysfs node
P0P2      S4     disabled
P0P3      S4     disabled
P0P1      S4     disabled  pci:0000:00:1e.0
UAR1      S4     disabled  pnp:00:0c
EUSB      S4     disabled  pci:0000:00:1d.7
USBE      S4     disabled  pci:0000:00:1a.7
P0P5      S4     disabled
P0P6      S4     disabled
P0P7      S4     disabled
P0P8      S4     disabled  pci:0000:00:1c.4
P0P9      S4     disabled  pci:0000:00:1c.5
GBEC      S4     disabled
USB0      S4     enabled   pci:0000:00:1d.0
USB1      S4     enabled   pci:0000:00:1d.1
USB2      S4     enabled   pci:0000:00:1d.2
USB3      S4     disabled
USB4      S4     enabled   pci:0000:00:1a.0
USB5      S4     enabled   pci:0000:00:1a.1
USB6      S4     disabled  pci:0000:00:1a.2
P0P4      S4     disabled  pci:0000:00:1c.0
My current local.rc file:
echo USB6>/proc/acpi/wakeup
echo USB5>/proc/acpi/wakeup
echo USB4>/proc/acpi/wakeup
echo USB3>/proc/acpi/wakeup
echo USB2>/proc/acpi/wakeup
echo USB1>/proc/acpi/wakeup
echo USB0>/proc/acpi/wakeup
echo "rc.local has completed sucessfully." >> /tmp/resume.log
exit 0
However, I have tried similar script in rc.local but with the same result, it will enable the USB but will not wake from MCEUSB
#Enable wakeup for the remote
status=`cat /proc/acpi/wakeup | grep "USB1" | awk {'print $3}'`
if [ "$status" = "disabled" ]; then
echo "USB1" > /proc/acpi/wakeup
fi
status=`cat /proc/acpi/wakeup | grep "USB0" | awk {'print $3}'`
echo "USB0" > /proc/acpi/wakeup
fi
exit 0
I have followed info and procedures step by step from:
http://wiki.xbmc.org/index.php?title=Enable_Wake-On-Device
http://wiki.xbmc.org/?title=Create_a_resume_script
Followed it step by step, installing curl, creating script.
http://wiki.xbmc.org/index.php?title=Ubuntu_Suspend_/_Wake
This procedure is incomplete and not clear. It was made for ubuntu 9 and PolicyKit folder does not exist in ubuntu 10.04
http://lars.werner.no/?p=177
step by step info here too.
http://forum.xbmc.org/showthread.php?p=480705
I am just exhausted Oo and very pissed Stare that everything works but not the wakeup. I have tried different USB ports but it is still the same. The IR receiver works fine since it works flawless in XBMC and it did wake the computer in windows. I have come too far with the setup to quit now. Could anyone please advise me? Rolleyes
System config:
MB: Asus P5G43T-M PRO
Intel Dual Core @2.8GHz
2Gb DDR3
Video: Intel GMA X4500 on board
Thank you for reading this.
