Full Version: problem with dependencies
I got this today when I was trying to install the nightly release. After removing the stable one.
I read through the entire forum(well almost) but couldn't find anything.
Anyone have any suggestions?
sudo aptitude install xbmc
Reading package lists... Done
Building dependency tree
Reading state information... Done
Reading extended state information
Initializing package states... Done
The following packages are BROKEN:
xbmc-data
The following NEW packages will be installed:
libmicrohttpd5{a} libmikmod2{a} libpcrecpp0{a} libqt3-mt{a}
libsdl-mixer1.2{a} libsmpeg0{a} python-qt3{a} python-sip{a} xbmc
xbmc-bin{a} xbmc-skin-confluence{a} xbmc-web{a}
0 packages upgraded, 13 newly installed, 0 to remove and 0 not upgraded.
Need to get 34.3MB/44.7MB of archives. After unpacking 107MB will be used.
The following packages have unmet dependencies:
xbmc-data: Depends: xbmc-bin (< 1:10.08~svn32246-lucid1.1~) but 1:10.08~svn32268-lucid1 is to be installed.
The following actions will resolve these dependencies:
Keep the following packages at their current version:
xbmc [Not Installed]
xbmc-data [Not Installed]
xbmc-skin-confluence [Not Installed]
xbmc-web [Not Installed]
Score is -9854
Got it working by manually download and installing xbmc-bin version 1:10.08~svn32246-lucid1.1.
And then run "aptitude install xbmc" did the trick.
But now I can't get digital audio to work, just analog.
Had the same problem with the stable release, but by adding alsa:plughw:0,3 under system -> audio solved that problem. Though I had to quickly change from digital -> analog and then back digital again to get DTS to work.
With that said i'am going back to the stable release where I actually can get the digital audio to work, by doing the trick mentioned above.
i have the same problem...but if i try to install xbmc-bin version 1:10.08~svn32246-lucid1.1 with .deb i get dependency problems...Sad
so i try "apt-get -f install" and also to install xbmc-bin dependecy package upgrade xbmc-bin Eek
i use ubuntu karmik and team-xbmc-svn repository...any suggest?
EDIT: ehm...solved with the right .deb xbmc-bin_10.08~svn32246-karmic1_amd64.deb for my distribution!
thanks for your solution!
