Full Version: Video thumb doesn't change until library update
When I change a thumbnail for the TV show series, season or show it only takes effect once I restart xbmc or update the library. Fan art on the other hand does take effect immediately.
Any ideas?
I'm running the confluence skin with the camelot release.
It should take effect immediately (I presume you're doing this from the "Get Thumb" option on the video information dialog). If it doesn't it means that for whatever reason a texture couldn't be free'd.
Hi jmarshall. Here's a little more information. Maybe this will help.
I turned on debug logging. I then started xbmc in which I navigated to movies, pressed the info button over the first movie (2012), changed the thumbnail with Get Thumb, then navigated back to the home screen with BKSP and closed XBMC.
I believe this is the relivent part of the log file:
01:26:16 T:2240 M:1568899072   DEBUG: CDVDDemuxFFmpeg::Open - probing failed, re-probing with probe size [2048]
01:26:16 T:2240 M:1567830016   DEBUG: CDVDDemuxFFmpeg::Open - probing failed, re-probing with probe size [4096]
01:26:16 T:2240 M:1567719424   DEBUG: CDVDDemuxFFmpeg::Open - probing failed, re-probing with probe size [8192]
01:26:16 T:3720 M:1568309248   DEBUG: CImageLoader::DoWork - took 496 ms to load special://masterprofile/Thumbnails/Video/0/0ed8e9ae.tbn
01:26:16 T:2240 M:1567436800   DEBUG: CDVDDemuxFFmpeg::Open - probing failed, re-probing with probe size [16384]
01:26:16 T:2240 M:1566928896   DEBUG: CDVDDemuxFFmpeg::Open - probing failed, re-probing with probe size [32768]
01:26:16 T:2240 M:1566031872   ERROR: CDVDDemuxFFmpeg::Open - error probing input format, D:\Movies\Suspiria (1977)\Suspiria.avi
01:26:19 T:2636 M:1575542784   DEBUG: CVideoDatabase::GetMovieId (D:\Movies\2012 (2009)\2012.avi), query = select idMovie from movie where idFile=571
01:26:19 T:2636 M:1575534592   DEBUG: CVideoDatabase::GetMovieId (D:\Movies\2012 (2009)\2012.avi), query = select idMovie from movie where idFile=571
01:26:19 T:2636 M:1575493632   DEBUG: ------ Window Init (DialogVideoInfo.xml) ------
01:26:19 T:2636 M:1575493632    INFO: Loading skin file: DialogVideoInfo.xml
01:26:19 T:2636 M:1575464960   DEBUG: Load DialogVideoInfo.xml: 63.10ms
01:26:19 T:2636 M:1575596032   DEBUG: Alloc resources: 65.87ms (63.30 ms skin load)
01:26:21 T:2636 M:1573580800    INFO: Loading skin file: FileBrowser.xml
01:26:21 T:2636 M:1573568512   DEBUG: Load FileBrowser.xml: 18.68ms
01:26:21 T:3600 M:1573568512   DEBUG: thread start, auto delete: 0
01:26:21 T:2376 M:1573568512   DEBUG: thread start, auto delete: 0
01:26:21 T:2636 M:1573568512   DEBUG: ------ Window Init (FileBrowser.xml) ------
01:26:21 T:464 M:1573568512   DEBUG: thread start, auto delete: 0
01:26:21 T:2636 M:1573568512   DEBUG: Alloc resources: 1.49ms (0.00 ms skin load)
01:26:21 T:2376 M:1573568512   DEBUG: FileCurl::Open(07C7FA8C) http://hwcdn.themoviedb.org/posters/deb/4bc9418f017a3c57fe01bdeb/2012-original.jpg
01:26:21 T:464 M:1573568512   DEBUG: FileCurl::Open(0924FA8C) http://hwcdn.themoviedb.org/posters/df0/4bc9418f017a3c57fe01bdf0/2012-original.png
01:26:21 T:2376 M:1573568512    INFO: XCURL::DllLibCurlGlobal::easy_aquire - Created session to http://hwcdn.themoviedb.org
01:26:21 T:464 M:1573568512    INFO: XCURL::DllLibCurlGlobal::easy_aquire - Created session to http://hwcdn.themoviedb.org
01:26:21 T:3600 M:1573568512   DEBUG: FileCurl::Open(06F7FA8C) http://hwcdn.themoviedb.org/posters/df5/4bc94190017a3c57fe01bdf5/2012-original.jpg
01:26:21 T:3600 M:1573568512    INFO: XCURL::DllLibCurlGlobal::easy_aquire - Created session to http://hwcdn.themoviedb.org
01:26:23 T:2376 M:1569845248   DEBUG: FileCurl::Close(07C7FA8C) http://hwcdn.themoviedb.org/posters/deb/4bc9418f017a3c57fe01bdeb/2012-original.jpg
01:26:23 T:2376 M:1569845248    INFO: Creating album thumb from memory: special://masterprofile/Thumbnails/Pictures/a/a59f7aa2.tbn
01:26:23 T:3600 M:1567711232   DEBUG: FileCurl::Close(06F7FA8C) http://hwcdn.themoviedb.org/posters/df5/4bc94190017a3c57fe01bdf5/2012-original.jpg
01:26:23 T:3600 M:1567711232    INFO: Creating album thumb from memory: special://masterprofile/Thumbnails/Pictures/a/ac1d41cc.tbn
01:26:23 T:2376 M:1565892608   DEBUG: FileCurl::Open(07C7FA8C) http://hwcdn.themoviedb.org/posters/dfa/4bc94191017a3c57fe01bdfa/2012-original.jpg
01:26:23 T:3600 M:1568010240   DEBUG: FileCurl::Open(06F7FA8C) http://hwcdn.themoviedb.org/posters/dff/4bc94191017a3c57fe01bdff/2012-original.jpg
01:26:24 T:2776 M:1567440896   DEBUG: CImageLoader::DoWork - took 193 ms to load special://masterprofile/Thumbnails/Pictures/a/a59f7aa2.tbn
01:26:24 T:464 M:1567313920   DEBUG: FileCurl::Close(0924FA8C) http://hwcdn.themoviedb.org/posters/df0/4bc9418f017a3c57fe01bdf0/2012-original.png
01:26:24 T:464 M:1567313920    INFO: Creating album thumb from memory: special://masterprofile/Thumbnails/Pictures/a/a8dc5c7b.tbn
01:26:24 T:2376 M:1561772032   DEBUG: FileCurl::Close(07C7FA8C) http://hwcdn.themoviedb.org/posters/dfa/4bc94191017a3c57fe01bdfa/2012-original.jpg
01:26:24 T:2376 M:1561772032    INFO: Creating album thumb from memory: special://masterprofile/Thumbnails/Pictures/b/b25a11c9.tbn
01:26:25 T:3600 M:1561190400   DEBUG: FileCurl::Close(06F7FA8C) http://hwcdn.themoviedb.org/posters/dff/4bc94191017a3c57fe01bdff/2012-original.jpg
01:26:25 T:3600 M:1561157632    INFO: Creating album thumb from memory: special://masterprofile/Thumbnails/Pictures/b/b69b0c7e.tbn
01:26:25 T:464 M:1562533888   DEBUG: FileCurl::Open(0924FA8C) http://hwcdn.themoviedb.org/posters/e04/4bc94192017a3c57fe01be04/2012-original.jpg
01:26:25 T:2376 M:1556819968   DEBUG: Thread 2376 terminating
01:26:25 T:3600 M:1562058752   DEBUG: Thread 3600 terminating
01:26:26 T:464 M:1562378240   DEBUG: FileCurl::Close(0924FA8C) http://hwcdn.themoviedb.org/posters/e04/4bc94192017a3c57fe01be04/2012-original.jpg
01:26:26 T:464 M:1562378240    INFO: Creating album thumb from memory: special://masterprofile/Thumbnails/Pictures/b/bbd82aa7.tbn
01:26:26 T:464 M:1562193920   DEBUG: Thread 464 terminating
01:26:26 T:2636 M:1561792512   DEBUG: ------ Window Deinit (FileBrowser.xml) ------
01:26:27 T:3816 M:1569820672   DEBUG: CImageLoader::DoWork - took 377 ms to load special://masterprofile/Thumbnails/Video/Fanart/b8ed1728.tbn
01:26:29 T:2636 M:1570750464   DEBUG: SDLKeyboard: scancode: 0, sym: 8, unicode: 8, modifier: 0
01:26:29 T:2636 M:1570750464   DEBUG: CApplication::OnKey: 61448 pressed, action is 51
01:26:29 T:2636 M:1570746368   DEBUG: ------ Window Deinit (DialogVideoInfo.xml) ------
01:26:29 T:2636 M:1575075840   DEBUG: CGUIMediaWindow::GetDirectory (videodb://1/2/)
01:26:29 T:2636 M:1575075840   DEBUG:   ParentPath = [videodb://1/2/]
01:26:29 T:2636 M:1575006208   DEBUG: CVideoDatabase::GetSetsNav query: select sets.idSet,sets.strSet,count(1),count(files.playCount) from sets join setlinkmovie on sets.idSet=setlinkmovie.idSet join movie on setlinkmovie.idMovie=movie.idMovie join files on files.idFile=movie.idFile  group by sets.idSet
01:26:29 T:2636 M:1575010304   DEBUG: CVideoDatabase::GetMoviesByWhere query: select * from movieview where movieview.idmovie NOT in (select idmovie from setlinkmovie)
01:26:29 T:2636 M:1575530496   DEBUG: Time for actual SQL query = 28
01:26:29 T:2636 M:1575530496   DEBUG: Time to retrieve movies from dataset = 185
01:26:29 T:2636 M:1575534592   DEBUG: Saving fileitems [videodb://1/2/]
01:26:29 T:2636 M:1575518208   DEBUG:   -- items: 107, sort method: 23, ascending: true
01:26:29 T:1204 M:1575059456   DEBUG: thread start, auto delete: 0
01:26:30 T:3720 M:1574412288   DEBUG: CDVDDemuxFFmpeg::Open - probing failed, re-probing with probe size [2048]
01:26:30 T:3720 M:1574412288   DEBUG: CDVDDemuxFFmpeg::Open - probing failed, re-probing with probe size [4096]
01:26:30 T:3720 M:1574412288   DEBUG: CDVDDemuxFFmpeg::Open - probing failed, re-probing with probe size [8192]
01:26:30 T:3720 M:1574412288   DEBUG: CDVDDemuxFFmpeg::Open - probing failed, re-probing with probe size [16384]
01:26:30 T:1204 M:1574412288   DEBUG: Thread 1204 terminating
01:26:30 T:3720 M:1574424576   DEBUG: CDVDDemuxFFmpeg::Open - probing failed, re-probing with probe size [32768]
01:26:30 T:3720 M:1574424576   ERROR: CDVDDemuxFFmpeg::Open - error probing input format, D:\Movies\Suspiria (1977)\Suspiria.avi
01:26:30 T:2636 M:1574494208   DEBUG: SDLKeyboard: scancode: 0, sym: 8, unicode: 8, modifier: 0
01:26:30 T:2636 M:1574494208   DEBUG: CApplication::OnKey: 61448 pressed, action is 9
01:26:30 T:2636 M:1574453248   DEBUG: CGUIWindowManager::PreviousWindow: Deactivate
01:26:30 T:2636 M:1574453248   DEBUG: ------ Window Deinit (MyVideoNav.xml) ------
01:26:30 T:2636 M:1574449152   DEBUG: CGUIWindowManager::PreviousWindow: Activate new
01:26:30 T:2636 M:1574449152   DEBUG: ------ Window Init (Home.xml) ------
01:26:30 T:2636 M:1574449152    INFO: Loading skin file: Home.xml
01:26:31 T:2636 M:1574100992   DEBUG: Load Home.xml: 96.04ms
01:26:31 T:2636 M:1574060032   DEBUG: Alloc resources: 102.61ms (96.41 ms skin load)
01:26:31 T:2636 M:1563860992   DEBUG: CApplication::ExecuteXBMCAction : Translating XBMC.RunScript(special://skin/scripts/RecentlyAdded.py,limit=4)
01:26:31 T:2636 M:1563860992   DEBUG: CApplication::ExecuteXBMCAction : To XBMC.RunScript(special://skin/scripts/RecentlyAdded.py,limit=4)
01:26:31 T:2636 M:1563860992    INFO: initializing python engine.
01:26:31 T:2636 M:1563860992   DEBUG: Win32DllLoader::Load(special://xbmc/system/python/python24.dll)
01:26:31 T:2636 M:1563828224   DEBUG: LoadLibraryA('MSVCR71.dll')
01:26:31 T:2636 M:1563828224   DEBUG: LoadLibrary('MSVCR71.dll') returning: 01E576C0
01:26:31 T:2636 M:1564078080   DEBUG: LoadLibraryExA called with flags:
To be honest I can't remember whether this was 100% working in Camelot or not.
Try a nightly and see if it works there.
