Try this file for testing:
Earth 2007 1080p BluRay x264
[email protected]
It peaks at 30Mbit and is within all normal specs of h264
[email protected]
If you can smoothly play the birdscene in this file you can play any file that is within the h264 specs
* * * MediaInfo Mac 0.7.33.4 file analysis report.
* * * MediaInfo Mac is ©2010 by Diego Massanti -
http://mediainfo.massanti.com
* * * MediaInfoLib by Jerome Martinez -
http://mediainfo.sourceforge.net
Created on: 1 aug 2010 10:25:56 GMT+02:00
Report for file: Earth 2007 1080p BluRay x264
[email protected]
General / Container Stream #1
Total Video Streams for this File.................1
Total Audio Streams for this File.................1
Total Subtitle Streams for this File..............1
Video Codecs Used.................................AVC
Audio Codecs Used.................................DTS
SubTitle Codecs Used..............................UTF-8
Available Sutbitle Languages......................English
File Format.......................................Matroska
Play Time.........................................1h 30mn
Total File Size...................................7.96 GiB
Total Stream BitRate..............................12.7 Mbps
Encoded with......................................mkvmerge v2.9.8 ('C'est le bon') built on Aug 13 2009 12:49:06
Encoding Library..................................libebml v0.7.7 + libmatroska v0.8.1
Video Stream #1
Codec (Human Name)................................AVC
Codec (FourCC)....................................V_MPEG4/ISO/AVC
Codec
[email protected]
Frame Width.......................................1 920 pixels
Frame Height......................................1 080 pixels
Frame Rate........................................23.976 fps
Total Frames......................................129504
Display Aspect Ratio..............................16:9
Scan Type.........................................Progressive
Color Space.......................................YUV
Codec Settings (Summary)..........................CABAC / 4 Ref Frames
QF (like Gordian Knot)............................0.239
Codec Settings (CABAC)............................Yes
Codec Settings (Reference Frames).................4
Video Stream Length...............................1h 30mn 1s 401ms
Video Stream BitRate..............................11.9 Mbps
Bit Depth.........................................8 bits
Video Stream Size.................................7.32 GiB (92%)
Video Encoder.....................................x264 - core 68 r1183M f21daff
Video Encoder (Settings)..........................cabac=1 / ref=4 / deblock=1:-2:-2 / analyse=0x3:0x113 / me=umh / subme=9 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=12 / nr=0 / decimate=1 / mbaff=0 / bframes=4 / b_pyramid=1 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40 / rc=2pass / bitrate=11900 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=50000 / vbv_bufsize=50000 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00
Video Stream Language.............................English
Audio Stream #1
Codec.............................................DTS
Codec (FourCC)....................................A_DTS
Audio Stream Length...............................1h 30mn 1s 398ms
Audio Stream BitRate..............................754 Kbps
Audio Stream BitRate Mode.........................CBR
Number of Audio Channels..........................6
Audio Channel's Positions.........................Front: L C R, Side: L R, LFE
Sampling Rate.....................................48.0 KHz
Bit Depth.........................................24 bits
Audio Stream Size.................................486 MiB (6%)
Audio Stream Title................................English DTS
Audio Stream Language.............................English
Subtitle Stream #1
Language..........................................English
Format............................................UTF-8
Codec ID..........................................S_TEXT/UTF8
Codec Info........................................UTF-8 Plain Text
