Full Version: Where are the movies?!
Hi there,
I have about 400 movies on a harddrive and I am running xbmc 9.11 on win 7.
Unfortunatelly xbmc shows only 248 inside the the db. Where are all the others? Some movies just do apear no matter what I do. Some others are scraped incorecctly.
Any ideas on how I can fix this permanently?
Thank you for any help,
merlin
I'd run them through ember media manager first as it will ask you to confirm each movie, Takes a while but once it's done it saves all the reliant info in your movies folder so you only have to do it once. Then once you install them into XBMC it will automatically know all the info from the movie folders.
Use IMDb scraper if your not already
thank you! I just tryed ember and it seems to be the solution I am looking for.
