2010-08-02, 05:02
I've spent all day trying different versions of live and ubuntu and I'm finally almost done. I've just ran into one problem I can't find by searching.
I have this wireless USB adapter:
http://www.newegg.com/Product/Product.as...6833166025
No matter what I tried it wouldn't work. Then I found these posts:
http://www.newegg.com/Product/ProductRev...th%20Linux
Which led me to this post:
http://ubuntuforums.org/showpost.php?p=8...ostcount=8
However this is my problem. I can't access blacklist.conf. If I use nano it just opens up a blank file.
I used FileZilla to confirm the file existed, and it already has this in it:
However I can't edit it in FileZilla either, it says I don't have the proper permissions.
I've tried using "sudo su" to run it as ROOT but the file still appeared blank.
Any ideas? Thanks in advance!
# This file lists those modules which we don't want to be loaded by
# alias expansion, usually so some other driver will be loaded for the
# device instead.
# evbug is a debug tool that should be loaded explicitly
blacklist evbug
# these drivers are very simple, the HID drivers are usually preferred
blacklist usbmouse
blacklist usbkbd
# replaced by e100
blacklist eepro100
# replaced by tulip
blacklist de4x5
# causes no end of confusion by creating unexpected network interfaces
blacklist eth1394
# snd_intel8x0m can interfere with snd_intel8x0, doesn't seem to support much
# hardware on its own (Ubuntu bug #2011, #6810)
blacklist snd_intel8x0m
# Conflicts with dvb driver (which is better for handling this device)
blacklist snd_aw2
# causes failure to suspend on HP compaq nc6000 (Ubuntu: #10306)
blacklist i2c_i801
# replaced by p54pci
blacklist prism54
# replaced by b43 and ssb.
blacklist bcm43xx
# most apps now use garmin usb driver directly (Ubuntu: #114565)
blacklist garmin_gps
# replaced by asus-laptop (Ubuntu: #184721)
blacklist asus_acpi
# low-quality, just noise when being used for sound playback, causes
# hangs at desktop session start (Ubuntu: #246969)
blacklist snd_pcsp
# ugly and loud noise, getting on everyone's nerves; this should be done by a
# nice pulseaudio bing (Ubuntu: #77010)
blacklist pcspkr
# EDAC driver for amd76x clashes with the agp driver preventing the aperture
# from being initialised (Ubuntu: #297750). Blacklist so that the driver
# continues to build and is installable for the few cases where its
# really needed.
blacklist amd76x_edac
