I am running XBMC live 9.11 on an aspire revo with 2GB ram and a dual-core atom 330. It plays everything except for the occasional MP4 file. At first it wasn't bothering me but now it's pissing me off. I have an example, and here is the info from GSpot:
CONT_AUDIO_STREAM_COUNT 1
CONT_BASETYPE Undetermined MP4 (.MP4) file
CONT_BYTES_MISSING
CONT_INTERLEAVE_ALIGN
CONT_INTERLEAVE_PRELOAD
CONT_INTERLEAVE_TIME
CONT_SUBTYPE
CONT_TOTAL_BITRATE 0
VIDEO_ASPECT_CONVERT_AVI1
VIDEO_ASPECT_CONVERT_AVI2
VIDEO_ASPECT_CONVERT_CVD1
VIDEO_ASPECT_CONVERT_CVD2
VIDEO_ASPECT_CONVERT_DVD1
VIDEO_ASPECT_CONVERT_DVD2
VIDEO_ASPECT_CONVERT_SVCD1
VIDEO_ASPECT_CONVERT_SVCD2
VIDEO_ASPECT_CONVERT_VCD1
VIDEO_ASPECT_CONVERT_VCD2
VIDEO_ASPECT_SOURCE_MATCH
VIDEO_ASPECT_TYPE_NTSC
VIDEO_ASPECT_TYPE_PAL
VIDEO_BITRATE 869
VIDEO_CODEC_NAME H.264/MPEG-4 AVC
VIDEO_CODEC_STATUS Codec Status Undetermined
VIDEO_CODEC_TYPE avc1
VIDEO_DAR 1.783
VIDEO_DURATION 48:41.334
VIDEO_FIELDS_PER_SEC
VIDEO_FRAME_COUNT 70004
VIDEO_FRAMES_PER_SEC 23.976
VIDEO_H264
VIDEO_MPEG2
VIDEO_MPEG2_3X2
VIDEO_MPEG2_BFF
VIDEO_MPEG2_I_L
VIDEO_MPEG2_PPF
VIDEO_MPEG2_PROG
VIDEO_MPEG2_TFF
VIDEO_MPEG4
VIDEO_MPEG4_BVOP
VIDEO_MPEG4_GMC
VIDEO_MPEG4_NVOP
VIDEO_MPEG4_QPEL
VIDEO_PAR
VIDEO_PICS_PER_SEC 23.976
VIDEO_QF 0.088
VIDEO_SAR 1.783
VIDEO_SIZE_X 856
VIDEO_SIZE_Y 480
AUDIO_BITRATE 128
AUDIO_BITRATE_TYPE
AUDIO_CHANNEL_COUNT 2
AUDIO_CODEC mp4a: MPEG-4 AAC LC
AUDIO_CODEC_STATUS Codec Status Undetermined
AUDIO_MPEG_STREAM_ID
AUDIO_MPEG_SUBSTREAM_ID
AUDIO_SAMPLE_RATE 48000
VLC Player 1.12 will play the file perfectly...
Is this an unsupported file/codec/container?! if so, is there any ETA on a fix? If not, is something wrong with my configuration? I have a nearly off-the-peg install of LIVE... Thanks in advance!!
Quote:Things we want from EVERY report:
1. "Latest" is NOT a revision, of ANYTHING! (See below)
2. Linux Distribution and Version (eg. Ubuntu 8.04, Gentoo 2007.0-r1, etc)
3. Architecture (eg. i686, x86_64, etc. See below.)
4. Install Method (PPA, RPM, build.sh, manual, other)
5. SVN Revision (See below.)
6. Detailed Instructions to Reproduce the Problem (The more specific the better.)
7. FULL Debug Log (Please use your favorite paste site! See below.) << NOT OPTIONAL!
8. Backtrace (Only attainable if XBMC has crashed. See below.)
9. Compiler Output (Only useful if XBMC doesn't build. See below.)
1) XBMC live 9.11
2/3) results of uname -a:
Linux XBMCLive 2.6.31-16-generic #53-Ubuntu SMP Tue Dec 8 04:01:29 UTC 2009 i686 GNU/Linux
4) XBMC Live installation CD .iso image from xbmc.org
5) I can't seem to find this. In my shutdown menu all I have is "exit xbmc, restart, shutdown and suspend" nothing about system info.
6) i just now attempted changing from VDPAU to software and it played the file! So maybe this is a bug in the nvidia driver?
$ cat /proc/driver/nvidia/version
NVRM version: NVIDIA UNIX x86 Kernel Module 190.53 Tue Dec 8 18:51:41 PST 2009
GCC version: gcc version 4.4.1 (Ubuntu 4.4.1-4ubuntu8)
7) Here is the log file output while playing the file in VDPAU:
08:38:53 T:3077466000 M:1443241984 NOTICE: DVDPlayer: Opening: smb://<filename removed to protect the innocent>
08:38:53 T:3077466000 M:1443241984 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
08:38:53 T:3019242352 M:1443241984 NOTICE: Creating InputStream
08:38:53 T:3019242352 M:1443241984 NOTICE: Creating Demuxer
08:38:54 T:3019242352 M:1437773824 NOTICE: Opening video stream: 0 source: 256
08:38:54 T:3019242352 M:1437773824 NOTICE: Creating video codec with codec id: 28
08:38:54 T:3019242352 M:1437773824 NOTICE: CDVDVideoCodecFFmpeg::Open() Creating VDPAU(856x480)
08:38:54 T:3019242352 M:1437200384 NOTICE: vdp_device = 0x00000001 vdp_st = 0x00000000
08:38:54 T:3019242352 M:1437200384 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 (VDPAU acceleration)
08:38:54 T:3019242352 M:1437200384 NOTICE: Creating video thread
08:38:54 T:3019242352 M:1437200384 NOTICE: Opening audio stream: 1 source: 256
08:38:54 T:76721008 M:1437200384 ERROR: (VDPAU) ReleasePixmap called without valid pixmap
08:38:54 T:3019242352 M:1437200384 NOTICE: Finding audio codec for: 86018
08:38:54 T:76721008 M:1437200384 NOTICE: running thread: video_thread
08:38:54 T:3019242352 M:1437200384 NOTICE: Creating audio thread
08:38:54 T:2962226032 M:1437200384 NOTICE: running thread: CDVDPlayerAudio::Process()
08:38:54 T:76721008 M:1437200384 NOTICE: Creating 1920x1080 pixmap
08:38:54 T:2962226032 M:1437200384 WARNING: CDVDMessageQueue(audio)::Get - retrieved last data packet of queue
08:38:54 T:2962226032 M:1437200384 NOTICE: Creating audio device with codec id: 86018, channels: 2, sample rate: 48000, no pass-through
08:38:54 T:76721008 M:1436446720 NOTICE: (VDPAU) Didnt find a Video Surface Available (Total: 0). Creating a new one. TRY #1
08:38:54 T:76721008 M:1435684864 NOTICE: (VDPAU) FiniVDPAUOutput
08:38:54 T:76721008 M:1435684864 NOTICE: (VDPAU) screenWidth:1920 vidWidth:856
08:38:54 T:76721008 M:1435684864 NOTICE: (VDPAU) screenHeight:1080 vidHeight:480
08:38:54 T:76721008 M:1435684864 ERROR: (VDPAU) Error: A catch-all error, used when no other error code applies.(25) at VDPAU.cpp:919
08:38:54 T:76721008 M:1435684864 NOTICE: (VDPAU) Total Output Surfaces Available: 4 of a max (tmp: 4 const: 4)
08:38:54 T:76721008 M:1435684864 NOTICE: VDPAU Decoder capabilities:
08:38:54 T:76721008 M:1435684864 NOTICE: name level macbs width height
08:38:54 T:76721008 M:1435684864 NOTICE: ------------------------------------
08:38:54 T:76721008 M:1435684864 NOTICE: MPEG1 0 8192 2048 2048
08:38:54 T:76721008 M:1435684864 NOTICE: MPEG2_SIMPLE 3 8192 2048 2048
08:38:54 T:76721008 M:1435684864 NOTICE: MPEG2_MAIN 3 8192 2048 2048
08:38:54 T:76721008 M:1435684864 NOTICE: H264_MAIN 41 8190 2032 2048
08:38:54 T:76721008 M:1435684864 NOTICE: H264_HIGH 41 8190 2032 2048
08:38:54 T:76721008 M:1435684864 NOTICE: VC1_SIMPLE 1 8190 2048 2048
08:38:54 T:76721008 M:1435684864 NOTICE: VC1_MAIN 2 8190 2048 2048
08:38:54 T:76721008 M:1435684864 NOTICE: VC1_ADVANCED 4 8190 2048 2048
08:38:54 T:76721008 M:1435684864 ERROR: (VDPAU) Error: An invalid handle value was provided.(3) at VDPAU.cpp:1115
08:38:54 T:76721008 M:1435684864 NOTICE: (VDPAU) Creating the video mixer
08:38:54 T:76721008 M:1432047616 NOTICE: fps: 23.976025, pwidth: 856, pheight: 480, dwidth: 856, dheight: 480
08:38:54 T:76721008 M:1432047616 NOTICE: Display resolution DESKTOP : 1920x1080 @ 50.00 - Full Screen (12)
08:38:54 T:76721008 M:1432047616 NOTICE: (VDPAU) Didnt find a Video Surface Available (Total: 1). Creating a new one. TRY #1
08:38:54 T:76721008 M:1431420928 ERROR: (VDPAU) Error: An invalid handle value was provided.(3) at VDPAU.cpp:1115
08:38:54 T:76721008 M:1431040000 ERROR: (VDPAU) Error: An invalid handle value was provided.(3) at VDPAU.cpp:1115
08:38:54 T:76721008 M:1430532096 ERROR: (VDPAU) Error: An invalid handle value was provided.(3) at VDPAU.cpp:1115
08:38:54 T:76721008 M:1430024192 ERROR: (VDPAU) Error: An invalid handle value was provided.(3) at VDPAU.cpp:1115
08:38:54 T:76721008 M:1429516288 ERROR: (VDPAU) Error: An invalid handle value was provided.(3) at VDPAU.cpp:1115
08:38:54 T:76721008 M:1427484672 ERROR: (VDPAU) Error: An invalid handle value was provided.(3) at VDPAU.cpp:1115
08:38:54 T:3077466000 M:1428119552 NOTICE: Using GL_TEXTURE_2D
08:38:54 T:3077466000 M:1428119552 NOTICE: GL: Using VDPAU render method
08:38:54 T:3077466000 M:1428119552 NOTICE: GL: NPOT texture support detected
08:38:54 T:76721008 M:1428119552 ERROR: (VDPAU) Error: An invalid handle value was provided.(3) at VDPAU.cpp:1115
08:38:54 T:3077466000 M:1427103744 NOTICE: Created m_glPixmapTexture (72)
08:38:54 T:76721008 M:1430786048 ERROR: (VDPAU) Error: An invalid handle value was provided.(3) at VDPAU.cpp:1115
08:38:55 T:3077466000 M:1430761472 NOTICE: CDVDPlayer::CloseFile()
08:38:55 T:76721008 M:1430761472 ERROR: (VDPAU) Error: An invalid handle value was provided.(3) at VDPAU.cpp:1115
08:38:55 T:3077466000 M:1430761472 NOTICE: DVDPlayer: waiting for threads to exit
08:38:55 T:3019242352 M:1430761472 NOTICE: CDVDPlayer::OnExit()
08:38:55 T:3019242352 M:1430761472 NOTICE: DVDPlayer: closing audio stream
08:38:55 T:3019242352 M:1430761472 NOTICE: Closing audio stream
08:38:55 T:3019242352 M:1430761472 NOTICE: Waiting for audio thread to exit
08:38:55 T:2962226032 M:1430761472 NOTICE: thread end: CDVDPlayerAudio::OnExit()
08:38:55 T:3019242352 M:1430761472 NOTICE: Closing audio device
08:38:55 T:3019242352 M:1430761472 NOTICE: Deleting audio codec
08:38:55 T:3019242352 M:1430761472 NOTICE: DVDPlayer: closing video stream
08:38:55 T:3019242352 M:1430761472 NOTICE: CDVDPlayer::OnExit() deleting demuxer
08:38:55 T:3019242352 M:1435713536 NOTICE: CDVDPlayer::OnExit() deleting input stream
08:38:55 T:3077466000 M:1435713536 NOTICE: DVDPlayer: finished waiting
08:38:55 T:3077466000 M:1435713536 NOTICE: Closing video stream
08:38:55 T:3077466000 M:1435713536 NOTICE: waiting for video thread to exit
08:38:55 T:76721008 M:1435713536 NOTICE: thread end: video_thread
08:38:55 T:3077466000 M:1436688384 NOTICE: deleting video codec
08:38:55 T:3077466000 M:1436688384 NOTICE: (VDPAU) ~CVDPAU
08:38:55 T:3077466000 M:1436688384 NOTICE: (VDPAU) FiniVDPAUOutput
08:38:55 T:3077466000 M:1436688384 ERROR: (VDPAU) Error: An invalid handle value was provided.(3) at VDPAU.cpp:824
08:38:55 T:3077466000 M:1441189888 NOTICE: CDVDPlayer::CloseFile()
08:38:55 T:3077466000 M:1441189888 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
08:38:55 T:3077466000 M:1441189888 NOTICE: DVDPlayer: waiting for threads to exit
08:38:55 T:3077466000 M:1441189888 NOTICE: DVDPlayer: finished waiting
and here is the output from changing the video processing to "software" from VDPAU:
08:40:36 T:3077466000 M:1442430976 NOTICE: DVDPlayer: Opening: smb://<filename removed to protect the innocent>
08:40:36 T:3077466000 M:1442304000 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
08:40:36 T:2962226032 M:1442304000 NOTICE: Creating InputStream
08:40:36 T:2962226032 M:1442304000 NOTICE: Creating Demuxer
08:40:36 T:2962226032 M:1436209152 NOTICE: Opening video stream: 0 source: 256
08:40:36 T:2962226032 M:1436209152 NOTICE: Creating video codec with codec id: 28
08:40:36 T:2962226032 M:1436209152 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
08:40:36 T:2962226032 M:1436082176 NOTICE: Creating video thread
08:40:36 T:2962226032 M:1436082176 NOTICE: Opening audio stream: 1 source: 256
08:40:36 T:2909776752 M:1436082176 NOTICE: running thread: video_thread
08:40:36 T:2962226032 M:1436082176 NOTICE: Finding audio codec for: 86018
08:40:36 T:2962226032 M:1436082176 NOTICE: Creating audio thread
08:40:36 T:2899286896 M:1436082176 NOTICE: running thread: CDVDPlayerAudio::Process()
08:40:36 T:2899286896 M:1436082176 WARNING: CDVDMessageQueue(audio)::Get - retrieved last data packet of queue
08:40:36 T:2899286896 M:1434812416 NOTICE: Creating audio device with codec id: 86018, channels: 2, sample rate: 48000, no pass-through
08:40:36 T:2909776752 M:1434812416 NOTICE: fps: 23.976025, pwidth: 856, pheight: 480, dwidth: 856, dheight: 480
08:40:36 T:2909776752 M:1434812416 NOTICE: Display resolution DESKTOP : 1920x1080 @ 50.00 - Full Screen (12)
08:40:37 T:3077466000 M:1429446656 NOTICE: Using GL_TEXTURE_2D
08:40:37 T:3077466000 M:1429446656 NOTICE: GL: Shaders support not present, falling back to SW mode
08:40:37 T:3077466000 M:1429446656 NOTICE: GL: NPOT texture support detected
08:40:40 T:3077466000 M:1430999040 NOTICE: CDVDPlayer::CloseFile()
08:40:40 T:3077466000 M:1430999040 NOTICE: DVDPlayer: waiting for threads to exit
08:40:40 T:2962226032 M:1430999040 NOTICE: CDVDPlayer::OnExit()
08:40:40 T:2962226032 M:1430999040 NOTICE: DVDPlayer: closing audio stream
08:40:40 T:2962226032 M:1430999040 NOTICE: Closing audio stream
08:40:40 T:2962226032 M:1430999040 NOTICE: Waiting for audio thread to exit
08:40:40 T:2899286896 M:1430999040 NOTICE: thread end: CDVDPlayerAudio::OnExit()
08:40:40 T:2962226032 M:1430999040 NOTICE: Closing audio device
08:40:40 T:2962226032 M:1431126016 NOTICE: Deleting audio codec
08:40:40 T:2962226032 M:1431126016 NOTICE: DVDPlayer: closing video stream
08:40:40 T:2962226032 M:1431126016 NOTICE: Closing video stream
08:40:40 T:2962226032 M:1431126016 NOTICE: waiting for video thread to exit
08:40:40 T:2909776752 M:1431126016 NOTICE: thread end: video_thread
08:40:40 T:2962226032 M:1431134208 NOTICE: deleting video codec
08:40:40 T:2962226032 M:1431134208 NOTICE: CDVDPlayer::OnExit() deleting demuxer
08:40:40 T:2962226032 M:1436086272 NOTICE: CDVDPlayer::OnExit() deleting input stream
08:40:40 T:3077466000 M:1436086272 NOTICE: DVDPlayer: finished waiting
08:40:40 T:3077466000 M:1441038336 NOTICE: CDVDPlayer::CloseFile()
08:40:40 T:3077466000 M:1441038336 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
08:40:40 T:3077466000 M:1441038336 NOTICE: DVDPlayer: waiting for threads to exit
08:40:40 T:3077466000 M:1441038336 NOTICE: DVDPlayer: finished waiting
08:25:23 T:3077466000 M:1493819392 NOTICE: Starting XBMC, Platform: GNU/Linux. Built on Dec 24 2009 (SVN:26018)
Go under settings and turn debugging on, then reboot. After reboot try to play that file. Use pastebin to paste the entire debug log.
856 is an unsupported width on ion because of a hardware bug, the nvidia driver detects that and then fails to set up vdpau.
For some reason we don't fall back to software decoding here.
because that code wasn't in camelot bobo
Here is the entire logfile with debugging on. No criticisms of the contents of my C drive, please (which I neglected to strip, even though it would have been easy with grep -v heh):
http://pastebin.com/raw.php?i=gUfbpW8L
If I put the video settings to autodetect, will it TRY vdpau first and then fall back to software, because this file works fine in software... Can I specify that somewhere?
If this is a bug in the ION chipset, is there a BIOS firmware update coming (a man can hope, right?)
blm14 Wrote:If I put the video settings to autodetect, will it TRY vdpau first and then fall back to software, because this file works fine in software... Can I specify that somewhere?
Yes, but only in newer versions. You need to upgrade. Either use on of the nightlies/svn or wait for Dharma.
The last time that I upgraded XBMC wouldn't boot up and I had to reinstall from the CD image. I forget - does the XBMC live install include aptitude sources for XBMC? Would that even work or should I just go directly to SVN?
