2011-07-14, 07:33
einhänder - I have not tested external ffmpeg with AE, but it should work with any recent version as the DTS-HD and TrueHD processing code is built into AE and does not rely on ffmpeg.
SpectreX Wrote:The sad thing is the gnif is working all by himself on some serious hardcore coding and mathematical algortims to put XBMC in same league in terms of audio with the other solutions like ffdshow, yet the rest of the developers are working on pseudo-useless features like dirty regions, to give a speed bump on an application that is already the fastest in the HTPC realm. Thanks again gnif for all the hard work
Calvados Wrote:Did a few test with latest commits... it's really good, DTS-HD MA worked on the two movies I tried, and it seems that my FLAC issue has been fixed as well (consistently plays with the right samplerate/channels even after a passthrough). Will most likely do more tests tonight.
rayhawk0 Wrote:That's really cool. For me i't working a little different. I'm using the HDMI from an Nvidia GTX 460 and DTS HD MA and Dolby HD bitstreaming is working, but when I play my 24 bit Flac files, the sample rate does not match the source.
In Foobar with WASAPI, when I play a 2ch 192kHz flac, my receiver shows that it is receiving a 2 ch 192kHz stream and when I play a 6 channel 96kHz flac, my receiver will reflect that.
In XBMC, it is almost always in multichannel 96kHz, regardless of the flac source.
As of what build are the flac files playing at the correct samplerate/channels for you?
