2012-01-28, 22:12
Ok with latest build I'm getting crackling on some 2ch mp3s the source of these are unknown so it could be the files but I listen to music every day with AE and never had this before this is on Linux btw
DEBUG: CAESinkALSA::InitializeHW - Setting timeout to 16 ms
21:22:29 T:140341067360000 INFO: CSoftAE::Initialize - ALSA Initialized:
21:22:29 T:140341067360000 INFO: Output Device : hdmi:AES0=0x06,AES1=0x82,AES2=0x00,AES3=0x0e
21:22:29 T:140341067360000 INFO: Sample Rate : 192000
21:22:29 T:140341067360000 INFO: Sample Format : AE_FMT_S16NE
21:22:29 T:140341067360000 INFO: Channel Count : 8
21:22:29 T:140341067360000 INFO: Channel Layout: FL,FR,BL,BR,FC,LFE,SL,SR
21:22:29 T:140341067360000 INFO: Frames : 2048
21:22:29 T:140341067360000 INFO: Frame Samples : 16384
21:22:29 T:140341067360000 INFO: Frame Size : 16
21:22:29 T:140341067360000 DEBUG: CDVDPlayerAudio:: synctype set to 0: clock feedback
21:22:29 T:140341138654976 DEBUG: CSoftAEStream::GetFrame - Underrun
21:22:29 T:140341067360000 DEBUG: CDVDPlayerAudio:: Discontinuity - was:522542.693000, should be:39805.712876, error:-482736.980124
21:22:29 T:140340874966784 DEBUG: CDVDPlayer::HandleMessages - player started 1
21:22:29 T:140341138654976 ERROR: CAESinkALSA::AddPackets - Timeout waiting for space
21:22:29 T:140341138654976 ERROR: Previous line repeats 6 times.
21:22:29 T:140341138654976 ERROR: CAESinkALSA::AddPackets - Underrun
21:22:29 T:140341079103232 DEBUG: AddOnLog: VDR XVDR Client: SendPing
21:22:30 T:140341138654976 ERROR: CAESinkALSA::AddPackets - snd_pcm_writei returned 0 (Success)
21:22:30 T:140341067360000 DEBUG: CDVDPlayerAudio:: Discontinuity - was:431098.359876, should be:239166.666667, error:-191931.693210
21:22:30 T:140341138654976 ERROR: CAESinkALSA::AddPackets - Timeout waiting for space
21:22:30 T:140341138654976 ERROR: Previous line repeats 7 times
gnif Wrote:@Gryph - Try and increase ALSA_PERIODS in "xbmc/cores/AudioEngine/Sinks/AESinkALSA.cpp" until the problem goes away, there was an error in the calculation of these values earlier, but obviously needs some tweaking for different hardware still.
Gryph Wrote:@DDDamian - How does this audiophile mode work? I have already compiled the latest commit with this in it, wanted to test it out.
DDDamian Wrote:The downside is: not cross-fading and a slight pause while your receiver switches it's internal processing to accomodate the new sample rate or channel count.
