I have a large library spread across several drives and some on a NAS. I want to know if there is a simple way to get some sort of notepad file that will list all of my movie titles?
thank you
As a start, if you have all of these movies indexed in XBMC's library, you can export your database as a single file and this creates an XML file containing all of your videos.
Yes, I have all of my movies indexed in XBMC. I went ahead and exported my library. I found the xml file. Now my question is how do I open access it properly? Double clicking on it opens up internet explorer with a bunch of code and a description for only one of my movies.
open the file with notepad in windows *right click* *open with*
-=jason=-
So I opened up the file with notepad, but it has a bunch of text (movie synopsis,runtime,etc).
I was hoping for just a simple clean list of movie titles (at most the movie directories)
Is this too much to hope for or can it be done easily?
You can open the xml in excel and then select only the columns you want to display.
I opened the xml file in Excel and deleted all the unneeded columns. It worked nicely. I was even able to save an extra copy as a notepad (.txt) file.
Thank you.
here is what I just did right now.
I was using command line and went into my movie directory
/mnt/1tb/Movies
I then typed ls
it listed all the folders I had in there in list form I then copied and pasted in to notepad++ its a notepad that has the lines numbered. I have 78 movies in my library
cheers,
-=Jason=-
if you're going to log in via the command line and do an 'ls' you might as well just redirect its output.
'ls > movies.txt'
This will basically take what would normally be displayed to your screen with 'ls' but instead dump it straight to a file named movies.txt which notepad should open without a problem.
