2010-08-04, 19:36
2010-08-04, 21:17
There's an OpenGL build of v9.11 at xbmcmce.sourceforge.net.
JR
JR
2010-08-04, 22:08
Ok, but it needs glew and everything apparently and I have no knowledge in getting this installed with extensions and all that.
No easy way out or am I stuck with a 9.11 stuttering at 1080p XBMC?
2010-08-04, 23:03
Getting an opengl build won't help you with that.
2010-08-05, 09:26
Shik Wrote:Ok, but it needs glew and everything apparently and I have no knowledge in getting this installed with extensions and all that.
The stuttering is likely to be because your CPU can't handle decoding 1080p, and an OpenGL build won't help. You could try the latest Dharma beta from http://mirrors.xbmc.org/nightlies/win32/ because this supports hardware acceleration. Note however that you need to be running Win7 or Vista, and you need a video card that supports DXVA2.
JR
2010-11-21, 03:19
jhsrennie Wrote:There's an OpenGL build of v9.11 at xbmcmce.sourceforge.net.
JR
SO, where is that OpenGL build of 9.11??
Couldn't find it at the site mentioned above. Any help would be appreciated.
2010-11-21, 10:20
I've removed it from the listing because there was little demand for it with Dharma just round the corner. If you reall want it try http://sourceforge.net/projects/xbmcmce/...p/download
NB this is just a modified XBMC.exe. You need to download and install the release XVBMC v9.11 from xbmc.org, then copy my modified exe over the standard one.
JR
JR
