is it possible to change the background color of the slideshow background from black to white?
I am setting up an slideshow which always contains images with white backgrounds, so it is neater to have a white background...
I wonder if you could utilize the background color stuff that was added to get it to clear to white. See this patch:
http://trac.xbmc.org/attachment/ticket/9...lear.patch
and try changing the <backgroundcolor> of the slideshow window to opaque white (ffffffff).
Cheers,
Jonathan
jmarshall Wrote:I wonder if you could utilize the background color stuff that was added to get it to clear to white. See this patch:
Cheers,
Jonathan
Tried the patch ... but did not work
Any other ideas?
I didn't say to try the patch. I said to try fiddling with the <backgroundcolor> tag in the slideshow window in a similar way as is done in the patch.
jmarshall Wrote:I didn't say to try the patch. I said to try fiddling with the <backgroundcolor> tag in the slideshow window in a similar way as is done in the patch.
Sorry that's what I mean ... I tried to work with the backgroundcolor tag in the slideshow xml, but no result..
