2010-08-06, 01:48
I just did an:
it removed XBMC from my system, so I did this:
what do I need to do? I run the latest packages usually. Something went wrong though. How can I fix this?
apt-get update && apt-get dist-upgrade
root@xbmc-live:~# sudo apt-get install xbmc
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
xbmc: Depends: xbmc-data (= 1:10.08~svn32246-lucid1) but it is not going to be installed
Depends: xbmc-skin-confluence (= 1:10.08~svn32246-lucid1) but it is not going to be installed
Depends: xbmc-web (= 1:10.08~svn32246-lucid1) but it is not going to be installed
E: Broken packages
root@xbmc-live:~# sudo apt-get purge xbmc*
.......................................... purging.................
E: Broken packages
root@xbmc-live:~# sudo apt-get install xbmc-standalone
xbmc-standalone: Depends: xbmc-data (= 1:10.08~svn32246-lucid1) but it is not going to be installed
E: Broken packages
root@xbmc-live:~#
