2010-08-06, 10:40
2010-08-06, 23:08
I tried using this then realized that if you're able to skin and want a exe to launch from the main dir, just use System.Exec or System.ExecWait. Works great with *.exe and *.bat, so far.
2010-08-07, 12:38
nd66 Wrote:I tried using this then realized that if you're able to skin and want a exe to launch from the main dir, just use System.Exec or System.ExecWait. Works great with *.exe and *.bat, so far.
Can you explain that?
2010-08-07, 18:06
athloni Wrote:Can you explain that?He is talking the python command which can be used from almost anywhere within xbmc (skin, key, addons)
2010-08-08, 15:16
Yep, I use it in my skin but it only works if no spaces are in the path.
http://forum.xbmc.org/showthread.php?p=5...post571985
I use windows don't know if linux has the same problem.
2010-08-08, 16:13
what should this be good for?
2010-08-08, 18:55
2010-09-11, 20:53
2010-09-14, 15:20
I try to use this to launch HuluDesktop (although I would prefer a link in the main menu). HuluDesktop launches fine, but doesn't have focus. Which means that I first have to click on it in order to get my remote to work. Does anybody know an attribute I can assign so this happens automatically?
