I have gotten the same error too.
Everything worked fine until i upgraded my installastion (openelec on raspberry pi). Cannot get the remote woking. Have tried: disabling password and changing port.
The web interface is running on port 80, have tried changing it to 8080.
have tried enabeling password, no go. Then disabeling it (no password), still the error.
EDIT: And now I read that its the app that needs an update.
I/O Exception (java.io.FileNotFoundException)
http://123.123.123.12:7070/
xbmcCmds/
xbmcHttp?command=GetSystemInfo(120)
What can i do?
I change the port and delete the password. nothing ... same error
The error is three since i update to frodo 12 rc2. :/
whois 123.123.123.12
Result apnic.net:
inetnum: 123.112.0.0 - 123.127.255.255
netname: UNICOM-BJ
descr: China Unicom Beijing province network
descr: China Unicom
country: CN
admin-c: CH1302-AP
tech-c: SY21-AP
mnt-by: APNIC-HM
mnt-lower: MAINT-CNCGROUP-BJ
mnt-routes: MAINT-CNCGROUP-RR
status: ALLOCATED PORTABLE
remarks: -+-+-+-+-+-+-+-+-+-+-+-++-+-+-+-+-+-+-+-+-+-+-+-+-+-+
remarks: This object can only be updated by APNIC hostmasters.
remarks: To update this object, please contact APNIC
remarks: hostmasters and include your organisation's account
remarks: name in the subject line.
changed: [email protected] 20070129
changed: [email protected] 20090507
changed: [email protected] 20090508
source: APNIC
...and so on and so on...
New member to the forum, but a long time user of XBMC. Have been using the remote for some time with my Windows based installations of XBMC, however for the life of me I can't get it to work with any of my Raspberry Pi installs.
Same error(s) as above.
http://my.ip.address:8080/
xbmcCmds/
Is this a known issue?
Are there plans to support the Pi with the remote or should we find a diff. remote that talks to all / any instances of XBMC. Windows, Linux, and Pi.
Much appreciated.
Cheers-
Loooool I'm pretty sure this is a conspiracy against Martijn
Getting a bit tired ... closing
