Full Version: ANSI or UTF-8?
I use Notepad++ for all my skinning and just recently noticed that it's encoding in ANSI as default. While I was experimenting using font shapes I found that I had to change this to encode in UFT-8 so I could use the decimal code to display them correctly in the label code.
ie
PHP Code:
<label>&#9660;</label>
<label>▼</label>
So the question is does this matter and what should be the default?
both are valid and which you use is just a matter of preference. in general we use utf-8 encoding for everything.
Thanks spiff.
spiff Wrote:both are valid and which you use is just a matter of preference. in general we use utf-8 encoding for everything.
Ok, will use UTF8 then, too.
EDIT: Oops, wrong thead
If you use UTF8, which I'd recommend, it pays to put a UTF8 declaration at the top of the XML file so XBMC knows it's setup that way (we make some assumptions that may or may not be correct otherwise).
