2010-08-08, 19:03
I finally got my pc running with xbmc and working sound, but i when i try to play any movies xbmc crashes. I am using Xbmcfreak LiveCD 10.08 svn32416.
I tried other install methods like minimal ubuntu server + xbmc and got the sound working but i still had the same crashes (even with the stable ppa). If i get a playback working the movie mostly plays fine. It lags sometimes.
some specs:
- Athlon X2 2x3Ghz
- 4GB RAM
- AMD Chipset
- Gainward G210 video
- Audio output to AV-Receiver through HDMI (onboard sound disabled)
- svn32416
- Ubuntu 10.04.1 i686 as installed with the Xbmcfreak Live-CD from 2nd August 2010 (no apt-get upgrade, because then alsa gets screwed up)
- skin: confluence (tried pm3.hd too, same problem)
error
XBMC crashes or hangs shortly after starting or when i stop playing movies. It also hangs when i press play to start the movie. i just get "Working" displayed for hours....
I don't know if these errors are connected, but it sure seems that way.
I tried different file types, but all have the same problem, it does'nt matter if i play a 15gb 1080p mkv movie or a 200 mb avi. I turned vdpau on and off, but nothing changed.
Backtrace
Debug Log
CrashLog
The strange thing is i can't really find anything in the debug or crashlog that could explain any of my crashes.
I would be grateful if anyone has any ideas. Thanks in advance!
Chanas
some specs:
- Athlon X2 2x3Ghz
- 4GB RAM
- AMD Chipset
- svn32416
error
Backtrace
Debug Log
CrashLog
Chanas
