Full Version: How to convert Blu-Ray DVD and HD DVD files
More and more people like me prefer to enjoying Blue-ray DVD and HD DVD , M2TS for their high quality of the images and good sound effect . But not all such files can be played on any player .
However ,recently I found a fantasy Blue-ray Converter called 4Videosoft Blu-Ray Converter .
It is a professional Blu-Ray DVD Converter and M2TS file converter which provides the ideal solution for you to convert Blu-Ray and M2TS file to HD video and Apple TV h.264 720P, HD WMV and popular video formats like AVI, MPEG, WMV, DivX, MP4, H.264/AVC, RM, MOV, XviD, 3GP, FLV, etc as well as audio formats.
This guide will offer you three specific procedural parts and some tips.
First: How to add your files ?
Second: How to convert the files that you want ?
Third: How to edit the files that you need ?
Tips: This converter also include the wonderful function of a professional iPhone transfer (* Transfer iPhone files to Computer
* Import PC file or folder to iPhone
* Transfer files between two iPhone
* Applicable to iPod as well)
System Requirements System Requirements
OS : Windows NT4/2000/2003/XP and Windows Vista, Windows 7
Hardware :Hardware Requirements: 800MHz Intel or AMD CPU, or above; 512MB RAM or more
Software : 4Videosoft Blu-Ray Converter .
First:How to add your files ?
Step 0: Download and install 4Videosoft
Blu-Ray Converter
Next :
1. Click the button “Load Blue-ray” to load Blu-Ray files and click the button “Load DVD” to load general DVD.
2. You can also click "File" menu to open the following drop-down menu, then select Load Blu-ray File, Blu-ray Disk, DVD, DVD Folder and IFO files.
3. Click the button “Add Video”to load local video/audio files.
Step 1: Set video encoding settings by setting Encoder, Frame Rate, Resolution and Bitrate.
Set audio encoding settings by setting Encoder, Channels, Bitrate and Sample Rate.
Step 2: After finishing all the necessary settings and editing, you can click the button “Convert” to start ripping your DVD.
Step 1:Click the button “Edit” to show all the function buttons you will need .
Step 2:As you like you can choose each of the buttons like “Effect”“Trim” “Crop” or “Watermark” .
For other users :
4Videosoft Blu-Ray Ripper
4Videosoft Blu-ray to iPad Ripper
4Videosoft Blu-ray to DivX Ripper
Other Blu-Ray Products:
4Videosoft Blu-Ray Products
Why posting this here ? This is completely out of topic ! And it looks like spam, you've got shares in 4Videosoft ?
Try to be less obvious in the future:
http://www.google.com/search?sourceid=ch...r9&qscrl=1
http://www.google.com/search?hl=en&safe=...=&gs_rfai=
