Full Version: AppleTV and new crystalhd driver/lib
Anyone running the atv(osx) with the crystalhd and the new driver/lib. How's memory usage. Is the driver memleak still present or does it seem fixed ?
waiting on compile version to test... or launcher.
curlyjs Wrote:waiting on compile version to test... or launcher.
same... once it hits launcher I'lll update
I'm at XBMC r32660 (ATV OSX), CrystalHD r145 and still using my old style bcm700012 card. Played parts of several 720p movies and part of one 1080p. Everything is looking and running fantastic (except my long running no AC3 - I'll post separately). Frames are keeping right up there and running very smooth. Looking excellent!!
On the System Info/Summary the free memory is at 51mb and memory used is 80%. I'll let it run overnight and check again in the morning.
Here's my top.
Let me know if I need to check anything differently.
tuckbodi Wrote:I'm at XBMC r32660 (ATV OSX), CrystalHD r145 and still using my old style bcm700012 card. Played parts of several 720p movies and part of one 1080p. Everything is looking and running fantastic (except my long running no AC3 - I'll post separately). Frames are keeping right up there and running very smooth. Looking excellent!!
Here's my top.
"PhysMem: 77.2M wired" is what I'm interested in. If this keeps growing as it did in the previous driver/lib, then crystalhd becomes unavailable for playback. That's the old driver mem leak.
can someone private msg me a link to compiled 145 driver Smile I would be happy to test out memory issue. I can get the rest of bits (firmware file) from elsewhere and install etc.
running - chd-osx-0.3.5.zip with SVN 32808 xbmc; had a few crashes
dmesg output
http://pastebin.com/K0hC9bFC
xbmc output
http://pastebin.com/r6jqKziH
medianfo
http://pastebin.com/w2W5thcM
herod98 Wrote:running - chd-osx-0.3.5.zip with SVN 32808 xbmc; had a few crashes
dmesg output
xbmc output
medianfo
crashreporter.log ?
Davilla, thanks once again for the hard work. 2.0.0 working fine here. Do you need so logs?
curlyjs Wrote:Davilla, thanks once again for the hard work. 2.0.0 working fine here. Do you need so logs?
LOL, not if it's working fine Smile
yep... but some video that I reported earlier are now working
someone school me on how to use the 2.0 r45 based macosx zip file, please?
davilla Wrote:LOL, not if it's working fine Smile
how are you supposed to fix what's not broken though Huh
