Full Version: Aeon Showmix 2.5 Custom Home menu issue
I've searched but have not found a resolution to my issue, I'm hoping someone can point me to the thread or give a direct answer:
Win7
XBMC
xbmc-r32150-Dharma
Showmix 2.5 B169
I was wanting to add a custom home menu to differentiate my HD and non HD movie collections. I followed the directions here which were pretty straightforward:
http://www.assembla.com/wiki/show/showmi...E_MENU%27S
I created two sources that are (movies and movies in HD) both with content set to movies. I set the Movies in HD as a favourite as there was already a menu option for movies.
The issue I'm having is when I go to configure the menu and add a custom category I select to add a fav and it goes to a new blank window with no further options.
I thought I'll cut my losses and just set up a subcategory under movies with Movies in HD, but that too gives me the same issue...
I tried installing the script.favorites from a thread I referenced but I couldn't install it bc I can't find the add-on option in showmix...
Any advice would be greatly appreciated.
rgshredder Wrote:I've searched but have not found a resolution to my issue, I'm hoping someone can point me to the thread or give a direct answer:
Win7
XBMC
xbmc-r32150-Dharma
Showmix 2.5 B169
Showmix isn't 100% Dharma compatible and at the moment not developed anymore.
See this thread:
http://forum.xbmc.org/showthread.php?tid=76737
